Pre-Amp / Power amp Tube Set for Dual Rectifier
WolfgangEngel
Post by WolfgangEngel » Mon Dec 10, 2018 11:04 am
Hi,
I am new to this board. I just bought my third Dual Rectifier and I am amazed by the tonal differences I hear between different Dual Rectifiers. After close inspection, I realized that this one had a very peculiar set of pre-amp tubes in it. So I was wondering what other people do? It seems the Pre-amp tubes give you a lot of control over the tone. Any tips for pre-amp tube sets? I am mostly looking for the early 90th sound. The amps are all early 90th.
More specific:
- what is the difference in tone between an STR 420 and an STR 440.
- it appears that the V5 ECC83 needs to be balanced. Anything special about that? There are sets that just have the same ECC83S balanced pre-amp tubes in every slot. Mine seems to have an interesting mix of RFT, JJ ECC83s and some Chinese tubes.
silentbob
Re: Pre-Amp / Power amp Tube Set for Dual Rectifier
Post by silentbob » Mon Dec 10, 2018 9:13 pm
I loved the old STR-420s and wish I could find something that sounds as good as they did. So far my favorite V1 tube is an EH 12AX7, though most people prefer the Tung Sol
WolfgangEngel
Post by WolfgangEngel » Tue Dec 11, 2018 2:09 pm
I bought a few extra now for future usage :-) It seems there is agreement that they sounded better than the STR 440.
V1 tube: I have an RFT in there. Do you know what the difference in sound between EH 12AX7 and Tung Sol or the RFT is? Instead of trying a lot of different 12AX7 I am hoping to get some feedback what already worked out for people.
silentbob
Post by silentbob » Thu Dec 20, 2018 11:11 pm
Sorry, I was on vacation.
The EH sounds thicker and has more low end. The Tung Sol has more top end and is smoother. I play a lot of 90s rock and no metal, so the EH fits my needs a lot better.
afu
Post by afu » Sat Dec 29, 2018 6:04 pm
The EHX 12AX7 has a spiral filament in it which is prone to failure when used in positions with high voltage on the cathode. Those are V3 and V4 on any Rectifier schematic I've ever seen.
I also like the EHX and Tung Sol tubes. I'm also really digging the high gain JJ ECC83s (which is also rebranded as Ruby 12AX7ACZ). They are low noise with gains over 100. Mine are all measured from 110 to 120. The theoretical gain of a 12AX7 is 100, so using them ensures you get maximum signal. I have a Tung Sol in V1 and the JJs in all the rest.
My Humble Music Tech Blog:
Dual Rectifier Index
GJgo
Post by GJgo » Tue Jan 01, 2019 8:59 am
I like Chinese or JJs pres in my Rectos.
Here's a 6L6 comparo I did that included 420s & 440s. I preferred the 420s in my Recto, but when they run out the 440 will be just fine.
https://youtu.be/j6JtsvSnRgI
Triple Rec G, Single Rec, Mini Rec, Tremoverb, Roadster, Rackto, Dual Rec MW, JP2C, Mark V, Five 35, IVb, IVa, III++ red DRG, III blue DRG, III blue DG, III blue KRG, IIC++ HRG, IIC++ DRG, IIC+ SR, IIC+ DR, IIB+ SR, IIB+ KRG.
tbonesullivan
Post by tbonesullivan » Tue Jan 22, 2019 10:03 am
"balanced" tubes for phase inverter use is somewhat controversial. Some say it's necessary, some say it's ok, some say it's marketing hype so that tube dealers can charge more.
What type of tubes make up the "peculiar" preamp tube set? Sounds like the previous owner rolled in some tubes, or dumped in their weird ones before selling it. There are a LOT of great used tubes around, which last quite a bit longer than the current production, so after years of use, they still test as new. The old production also in general are able to tolerate the out of spec cathode follower voltages that are often used. I know some people are down on the Russian Spiral filament designs, but it's a good design, and even the original 12AX7/ECC83 spec had only 180V as the cathode to heater voltage limiting value. MB used to use EHX preamp tubes as the "Russian 2" tubes before the Cathode Follower issue was noticed.
Anyway, hopefully MB will run out of the STR 440s so that they can get something different from Russia, Slovakia, or China. There have been a lot of new and improved tube designs coming out of all the factories,.
Guitars: Hamers, Heritages, G&L Legacies, EBMM Steve Morse, Carvin Bolt, Fender Tele
Amps: DC-5 1x12, Maverick 2x12, Stiletto ACE 1x12, Trem-O-Verb 2x12
