3ch MW back panel channel selector
Posted: Sat Sep 15, 2018 11:28 am
by Miro9486
Hi,
I’ve started using rotary switch to change channels on my 3ch MW recently. It behaves a bit weird. Going click by click, from ch1 towards ftsw - it goes ch1-ch2-ch1-ch3-ch1(ftsw w/out ftsw connected). Similar situation going back, with this one additional ch1 out of order. Is it normal situation? I had some problems with the head changin channels by itself that went away after changing footswitch.
Re: 3ch MW back panel channel selector
Posted: Mon Sep 17, 2018 1:01 pm
by Authorized Boogie
Miro9486 wrote:Hi,
If you rotate the switch slowly, its seeing the in-between positions as "no contact" and selecting the Default channel, CH1.
