Rectoverb 25 combo channel popping
Posted: Fri Aug 17, 2018 3:28 pm
by snyder17315
Hi all-
Just started having an issue with my ROV25 combo and popping noise switching between channels 1/2. Both are set to the same wattage (25w) and it doesn't matter if I use the footswitch or the front panel switch to change channels. Amp also sounds a little noiser than normal with some slight buzzing and white-ish noise. Could I have a power tube going bad? All tubes look fine and I didn't notice any odd noise or microphonics tapping them. Only other thing I noticed is some variation in the buzz/white-ish noise if I move the speaker cable around some in the back - doesn't affect the popping though. Thanks!
Re: Rectoverb 25 combo channel popping
Posted: Mon Aug 20, 2018 6:24 pm
by Authorized Boogie
snyder17315 wrote:Hi all-
That is often the sign of a power tube heading for failure. Hope that helps...
