It is currently Mon Jan 21, 2019 8:34 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: Dual Rectifier Solo Head
PostPosted: Sun Jun 24, 2018 1:03 pm
Got a new Recto, it is the version before the switchable 50/100 watt model. It has MESA STR 430 which i believe are the Sovtek 6L6WXT.
I have older Marshall & bias my own amps but am a noob when it comes to MESA tubes.
I like the Tungsol 6L6. Does MESA make those or can i just buy a non-MESA matched quad for my Recto ?
PostPosted: Sun Jun 24, 2018 4:17 pm
Sure. The quad doesn't even have to be a four tube match. Just as long as each PAIR is matched. Inner pair matched, outer pair matched.
However, Mesa tubes are a reliably good choice. As good as any, maybe better.
PostPosted: Sun Jun 24, 2018 5:31 pm
I have a Compu-bias meter i hooked up. In tube Rec mode {spongy} the output was only about 3 watts with around 300 volts on the plates.
Diode Rectification was around 460 volts & 14 watts output which is still cold.
70% dissipation @ 460 volts was about 51ma, my tubes had 31ma.
Is that low plate voltage normal in Tube Rec mode ?
PostPosted: Sun Jun 24, 2018 10:00 pm
The schematic says 472 volts on the plates. Being just 10 volts off (diode rectifiers) is only about 2 percent under spec. I'd call that good.
You're running at 43 percent dissipation.
But the tube rectifier output...that seems rather low. Are they all running? All putting out even amounts of heat?
PostPosted: Sun Jun 24, 2018 10:46 pm
Yes they were all lit up. One pair of 6L6's was older than the other. IDK if that has anything to do with it.
I bought a matched quad of Tungsol 6L6GC STR's.
https://www.ebay.com/itm/New-4x-Tung-So ... %7Ciid%3A1
PostPosted: Sun Jun 24, 2018 11:02 pm
Well, I'm not going to do it tonight, but I have a pair of triple recto solo heads and I'll crack one (or both) of them open and meter out the voltage in tube rectifier mode and let you know what it is. (diode and tube voltages both.)
I customized the knobs on the lower unit. Mesa had them, but I had to turn each pot upside down for them to fit right.
PostPosted: Mon Jun 25, 2018 5:27 am
Thanks man. Im a little leary of these Tungsol tubes not working out.
Hope all goes well.
PostPosted: Mon Jun 25, 2018 9:37 am
https://www.youtube.com/watch?v=MN-8j5vl4e0
-4db on the hot plate, tube rec setting, Bold switch on, very SLO-ish.
PostPosted: Sun Jul 08, 2018 7:44 am
So got to hang out in Obeids Amp Dungeon this morn, he modded my MESA parallel loop to series, sounds soooo much better. All my effects sound the way theyre suppose to.
He had old Marshall & old Pre Rola cabs all over the place, in the amp Lab chassis's everywhere. I saw 2 of Richard Fortus' amps a Plexi Super PA 100 watt & a 50 watt Super Trem JMP being modded. Fortus is a member of GnR and lives here in town. It was totally cool. thanks to Mr. Khan !!!
https://www.youtube.com/watch?v=OIuYWwdQTO8
PostPosted: Sat Jul 14, 2018 10:03 am
https://www.youtube.com/watch?v=r09DKNeNUf0&t=312s
Clippage ...
Users browsing this forum: No registered users and 10 guests
