The Presence controls from both Channels of my Dual Rec are tied together. Both adjust the Presence on both Channels.
Now here is the real delema:
This is THE BEST Recto Red Channel I have personally ever heard and I don't want to do ANYTHING to compromise that BUT, with it set right the clean channel is a bit muddy.
Anyone ever heard of that problem? Is that a result of some mod?
Weird Problem, NEED HELP!
JP-2C
1985 Mark iii Simul Class Black Dot w/Red Stripe upgrade
1987 Mark iii Coliseum Purple Stripe
1987 Red Stripe Combo
Mark IVb
Rocket 4Forty
JP2C (#2)
Mark IVb
Rocket 4Forty
JP2C (#2)
Re: Weird Problem, NEED HELP!
Is this a 2-ch recto, or 3?
They affect each other on the 2-ch heads, haven't played on a 3-ch in almost a decade.
B.C Rich Guitars
Mesa Amps/Cabs
Mesa Amps/Cabs
- Authorized Boogie
- Mark IV
- Contact:
Guessing this is a 2 channel head?BoogieHog wrote:The Presence controls from both Channels of my Dual Rec are tied together. Both adjust the Presence on both Channels.
From the User Manual:
NOTE: When the CHANNEL STYLE SELECT feature is used and the Modern Red channel is cloning Red to Vintage (so that it
sounds like the Orange channel) - be aware that both the Orange and Red channels' PRESENCE Controls are active in the (bottom)
Red channel in this setting only. Some amazing sounds are possible because the two PRESENCE Controls maintain their respective
voicing differences giving you two regions of top end harmonics to play with in this Mode.
