Rectifier Tubes
Hypieran
Rectifier Tubes
Post by Hypieran » Mon Feb 26, 2018 11:24 am
I have a single rectifier tube out on my Triple Rectifier. What does this do??? Amp plays fine I use silicon diode. But only 2 rectifier tubes work. Is this ok or should I fix it quickly???
Mesa Triple Rectifier 2008 3 CH
Jackson RR3 Japan Made
EMG 81/85
TS9
Decimator
Helix LT
Roland JC120
Authorized Boogie
Re: Rectifier Tubes
Post by Authorized Boogie » Mon Feb 26, 2018 1:11 pm
Hypieran wrote:I have a single rectifier tube out on my Triple Rectifier. What does this do??? Amp plays fine I use silicon diode. But only 2 rectifier tubes work. Is this ok or should I fix it quickly???
If you're not using the amp on the Tube Rectifier setting, you can simply remove them from the amp!
If you are using the Tube Rectifier setting, yes - you need all 3 tubes to be operational, as they supply the DC current supply to the power tubes (converted from the AC wall current).
Hypieran
Re: Rectifier Tubes
Post by Hypieran » Mon Feb 26, 2018 1:21 pm
Ok thanks didnt know that. I have used tube before with the one tube off and didn't notice a problem, but won't use it again until I get replacement tubes ordered all new power tubes, pre amp tubes, and rectifier tubes.
EMG 81/85
TS9
Decimator
Helix LT
Roland JC120
dennisl59
Re: Rectifier Tubes
Post by dennisl59 » Tue Feb 27, 2018 1:25 pm
Funny thing about Rectifier Tube(s).
My Lonestar 100 watt Rectifier Tube had a 'glassy rattle' but after I contacted Mesa Support they told me I could completely remove the tube IF I ran the amp in 'silicon diode' mode until I got a replacement tube. Of course in hindsight this make complete sense: The tube isn't 'active' at all, just powered up...until you move the switch from 'silicon diode' to 'tracking mode' and select 50 watts.
The replacement tube is on the way...
All of this was done using the Mesa Boogie Online Support Form system.
Lonestar 100 Head
Mark V:25
1x12 Widebody Closed Back C90
2x12 Lonestar Open Back C90's
dennisl59
Re: Rectifier Tubes
Post by dennisl59 » Wed Feb 28, 2018 7:24 pm
Tube replaced. Problem solved.
Lonestar 100 Head
Mark V:25
NoGlassNoClass
Re: Rectifier Tubes
Post by NoGlassNoClass » Wed Mar 07, 2018 10:19 pm
Yes this is correct. If you have a bad rec tube, you should remove all of them and use the silicon diode setting. Using the tube rec setting with a bad rectifier tube will blow the main fuse. Maybe even in diode setting if the bad tube is still in the amp.
Those who would surrender freedom for security deserve neither.
