It is currently Sun Jul 22, 2018 7:19 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 27, 2017 5:19 pm
DS-1 wrote:
I also tried to keep the master level as low as possible, using SEND at max and OUTPUT as needed.
I have channel 2 and 3 masters lower than 10 o clock. This because I should then put the clean master at 11-12 (and the gain clean also at 12) to match the volume and it starts to have a sort of crunchy sound.
What exactly does the cap on output?
I have a stock 3ch Triple Recto. What mod can I do to have a "2ch" similar sound?
Jumpering the cap on the Output pot, in practice, restores some of the low end lost when using Loop Active. IOW, it sounds a bit fuller (e.g., less tone suck). In theory I'm unsure why this is TBH. That pot has a 330K resistor in parallel tying the input to the wiper, with said cap in series. In my limited knowledge, I assumed this was a bright cap, but the opposite effect occurred when I jumpered it. It wasn't a night and day difference, but as with most things, small increments here and there contribute to the bigger picture. The brightness/fizziness is still present, but that can be dialed back with the treble/presence pots to some degree. For example, I keep the Treble at 2:00 with Loop Bypassed, but dial it back to 1:00 with Loop Active.
The only time I ever played a 2CH was waaay back in the early/mid nineties when I was just starting out on guitar. So, to answer your question, I'm not entirely sure. Search for "Pre 500 Recto" and there's a long thread about guys chasing said tone. Generally speak though, aside from those very early rectos (Rev C-E), they're all more or less the same. Sure, one small component can make a big impact, but whether or not that is "better" is entirely subjective.
Guitars:
Ibanez '98 RG7620 (EMG 81-7H, 60-7H)
Amps:
Triple Recto 3CH (modded), Studio Preamp (MK2C+ mods), 2x12 Recto Vertical cab
Past:
Mark V head, Rectoverb series 2 combo, F-30 combo, V-Twin rack pre
PostPosted: Thu Dec 28, 2017 10:50 am
Wow, this reply made my day!
I already did the "presence pot mod" on channel 3, changing the pot from stock to 25k and now channel 3 sounds very close to channel 2. A lot of fizzy is gone.
With caps mod I could improve the sound...
Is there any tutorial to do it? I believe it's a simple mod, but I want to be sure of doing the right jumper!
PostPosted: Wed Jan 03, 2018 8:21 pm
I recommend learning a bit more about tube amps and electronics in general before you attempt to mod your amp. No offense, but if you're unsure of what to jumper, that suggests you lack the basic knowledge of reading schematics and signal tracing the PCB. It's not hard to learn, but it's essential for your safety. YouTube has everything you need to know.
Guitars:
Amps:
Past:
PostPosted: Thu Jan 04, 2018 5:31 am
Yes, you're right!
I'd like to learn more about it, because i want to experiment before sell it to get a 2ch...that's why I want to know how the 3ch sounds with these mods. I can solder, but I need to improve my learning about electronics.
Do you think that it's possible to do a tutorial to make these mods easier?
PostPosted: Fri Jan 05, 2018 11:10 am
3-channel Rectos have 20uF filtering at the parallel power supply nodes of the preamp while 2-channels models have 30uF in these positions. Swap the two pairs of parallel 10uF electrolytic filter caps in the power supply with 15uF caps with similar (or better) specs. This task is not that simple as you have to lift the circuit board in order to work with the caps.
PostPosted: Sat Jan 06, 2018 6:29 am
Very cool mod! Have you tried It? How the sound changes?
Instead what about the 100ohm resistor to jumper?
PostPosted: Sat Jan 06, 2018 2:07 pm
Not on an actual Rectifier, but I've compared between 10uF, 20uF and 30uF caps on my SLO/Recto-clone I've built. In my experience, the higher you go, the more punchy, bigger and less compressed the amplifier feels. It feels as if the amp slightly cleans up. The lower value caps provide slightly less bottom-end and make the feel more compressed.
IMO, the 100ohm resistors on cathodes have somewhat unique effect. They slightly reduce the gain boost that the cathode caps provide and flatten the frequency response. This seems to result in a slightly more pronounced lowend with less upper mids and treble. This in turn increases the hair and grind when e.g. playing power chords which is one part of the Rectifier trademark tone. The price is paid in somewhat dampened attack. If the 100ohm resistors are jumped, there is slight gain increase in the mids and treble.
PostPosted: Wed Feb 28, 2018 7:18 pm
It's been a while since I've been around here. Had some real life stuff going that pulled me away from fun stuff, like modding amps. 8) . Anyway, I figured I should report back having put my amp through it's paces with my band.
Welp, I have to be honest. I've reversed a few of my mods. Fact is, Mesa pretty much "got it right" (no surprise TBH). I did keep some, which I'll go over shortly, but suffice to say that often times the "easiest" answer is many times the "best" answer. And the easiest solution is to just use a damn OD pedal in front of the amp lol.
So what did I reverse? The coupling caps were restored back to .02uf. Yes, using .0022's cleaned up the low end substantially, but at gig volumes the low end was just "off". It didn't "thump" in the right way. Instead it was just sort of boxy and odd. I also changed V1a bypass cap back to 1uf and reconnected the 2M2 load resistor. I kept all the other mods.
So, next up I'm going to mess with CH1 and see where it can go. I want to get more brightness out of it; something more Blackface. Going over the schematic there are plenty of areas to increase the top end. Should be interesting...
TL;DR: Just use a tubescreamer if you play metal with a recto. :twisted:
Guitars:
Amps:
Past:
PostPosted: Mon Mar 12, 2018 1:46 pm
I updated the page regarding the voicing circuit, gain, and load resistor.
My Humble Music Tech Blog:
Dual Rectifier Index
PostPosted: Sat Apr 07, 2018 5:56 am
I have a 2005 3ch Triple Rectifier and I'm doing some tone tests.
I need to use the FX loop on (I've modded it to have a serial loop, I have a lot of modulation pedals and I really like the SOLO function), and I'm experimenting what's the best tone according to my ears.
First, I used a very low master channel for 2 and 3 ch (master is at 11 for channel 2 set to VINTAGE and 8-9 for channel set to MODERN), with cranked SEND pot (very near to MAX level). In this way I can have a very clean channel. I like the sound of the clean channel, but channel 2 and 3 are too scooped. It seems like the mids don't come out due to the low master channel.
If I use different master channel volumes, the situation is a bit different: SEND know at 12, channel 2 at 1 o clock with VINTAGE setting and channel 3 at 10-11 o clock with MODERN setting. These channels now are really crunchy. I lowered the gain a bit, the tone is full of mids. But I can't have a real clean channel, because I need to push it hard to level the volumes with the other two channels (master at 3 o clock, gain around the same setting), but obviously it is WAY TOO cruncky to be a clean channel.
The question is: there no mod for the clean to at least match the volume level of the other two channels? Obviously I have this issue only when I use FX loop on and crank the master volume of the channel 2 and 3.
PostPosted: Sun Apr 08, 2018 6:56 pm
I have to commend people who post mods and are capable of modifying their amplifier but I'm not one of them.
The best solution I found for a tighter recto is to buy a Siemens E83CC triple mica for V1.
PostPosted: Sat Jun 23, 2018 6:31 pm
I've been using a Boss GE-7 EQ pedal in front of mine. Running it 12V with a crooked frown (max 0dB; min -10db) and the gain up to ~12dB. I now have a Switch DR pedal looper/midi controller to use it only when I need to.
I want a TC Electronic Spark Booster (4 knob) and/or a used Nova Drive for more options and flexibility.
PostPosted: Thu Jul 05, 2018 9:10 pm
The reason you're getting more mids and crunch when pushing the channel Outputs (or cranking the FX Send level) is because the tubes down stream of the tone stacks are beginning to distort. I'm not talking about power tube distortion; you're literally overdriving the FX send/return and/or the phase splitter (V4 and V5). There isn't anything wrong with that, but there's no way to get a clean tone when you're slamming those stages.
The volume discrepancy is the lack of negative feedback in the power section when in Modern mode. As you've noticed, if you want to have a truely "clean" channel 1, CH2/3 Modern output needs to be set around 9-10:00 at most.
The best way to get more mids out of CH2/3 Modern is to roll back the Bass. But to get that crunchy tone (from clipping V4/V5) you will have to sacrifice your clean tone.
Thinking about it, you *could* disconnect the NFB relay for CH1 (assuming it's even that easy) - that would give the clean channel a huge boost in volume. Would probably be much louder than Modern mode in fact. But unless you know what you're doing, I wouldn't go messing around as you'll more than likely screw things up.
Guitars:
Amps:
Past:
PostPosted: Thu Jul 05, 2018 9:22 pm
Thanks for sharing. Your site is one of the inspirations for me learning about tube amps. :mrgreen:
Oh, and speaking of boosting rectifiers and whatnot... I've started gather parts for a DIY amp build. The power amp is loosely based on a Fender DR (6V6 in p-p). For the preamp however, I'm flirting with the idea of building a SLO/Recto overdrive circuit with an additional gain stage and simplified tone stack tacked on the front end. Basically a Recto/Mark love child. The inspiration comes from the fact that so many Recto users resort to EQs, ODs, etc up front to filter out the lows, why not just build it into the amp itself?! I'll be building each section on separate turret boards so swapping out preamp "cards" should be relatively simple. I'll start a new thread once I get the ball rolling. :twisted:
Guitars:
Amps:
Past:
