Dual Rec. 3 channel request
NunoVanBamSteen
Chicagoland
Hey, I have an 02 dual rec solo hesd that developed a weird problem that I figured out quickly enough, but the secondary issue that I found many cold solder joints on the rectifier board.
As a result, while I was repairing one issue, another popped up.
A grey wire from the plus side of the 220uF caps dislodged from somewhere on the recto board. I think i have the answer from the schematics, but I would love it if someone has a gut shot that happens to show where the dang thing attaches. There is no obvious remnants of the wire break on the board.
Any help is appreciated.
NVBS
Solved my own problem. The schematics proved useful and it was the rectifier supply lead.
The amp is happy and healthy and amazing as ever!
