Multi-watt Dual recto clean ch. problem
Thegrayreed
Post by Thegrayreed » Wed Sep 20, 2017 8:27 pm
Tried the search function on the forum with no luck #noob
Anyway on my multi-watt dual recto I'm having a problem on the clean channel.
The problem is little to no volume, in other words you can barley hear it with the channel volume,gain, and master cranked all the way up, literally only a whisper of volume.
The other two channels are fine, no problems at all.
I've tried rolling a few different preamp tubes with no luck.
If it means anything the amp sat unplayed for around 7 months, the last time it was played it worked with no problems.
Any of you wise guys a have any ideas on what could be going on?
Thanks for looking!!!!
V3
Re: Multi-watt Dual recto clean ch. problem
Post by V3 » Thu Sep 21, 2017 2:21 am
Is it in 100 watt mode? Fx loop disengaged?
2012 Mesa Dual Rectifier Roadster Head
2006 Mesa Stiletto Deuce II
Thegrayreed
Post by Thegrayreed » Thu Sep 21, 2017 4:05 am
V3 wrote:Is it in 100 watt mode? Fx loop disengaged?
Yes sir, sure is.
MesaMad1378
Post by MesaMad1378 » Mon Apr 15, 2019 5:07 am
How did you go with this? Did you get anywhere? Mine is quiet to compared to ch 1 and 2. If I want it louder it starts to distort and I like my cleans like crystal.
Mesa Dual Rectifier, TriAxis, Recto Recording,
2:90, 2:100, SUS-4 16ru Case,
Flux Five, Throttle Box EQ, 5 Band EQ,
Straight Traditional 4x12 Cabs.
And other stuff!!
domct203
Post by domct203 » Mon Apr 15, 2019 5:27 pm
Where do you have your channel masters set?
I find that to keep the clean channel ‘clean’, I need to keep the lead channel Masters no higher than 9:30-10:00 with Modern mode, or 10:30-11:00 with Vintage mode. Any higher and the clean channel volume can’t compete without breaking up.
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
'18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
TC G-System
==> NOMAD on Facebook <==
