What was different about the Tremoverb?
Deadpool_25
I had the TOV combo for a short time and it was amazing (should've kept it). It seemed like a normal Dual Rec at higher gain settings but it also had what seemed to be much sweeter cleans. Other than the obvious Tremolo circuit, what was different between a TOV and a standard DR?
You mean comparing 2-channel Dual Rectifier and a Trem-o-Verb[ ? }
I have a ToV. I downloaded a 2-channel DR manual. All I could find difference between the two besides tremolo is reverb, otherwise they seem identical. Someone is going to chime and and say 2-Ch DR has more gain in the Red CH but a technician looked at both schematics and said they're identical unless there was a revision somewhere down the road.
