It is currently Fri Feb 23, 2018 9:36 am
 Post subject: PROBLEMS ON MINI RECT 25
PostPosted: Fri Jun 16, 2017 12:07 pm
Hi, I am Matias, I am from Argentina, sorry for my English, I have a Mini Rectifier for about 2 years, I have a problem, my amplifier when I turn the valves are activated, but the second turns everything off and only the Indicates the channel in which the equipment is. I hope you can guide me that it could be. Thank you sorry if it is not the correct way to do the consultation is the first time I do it
I do not know how to attach photos or videos of what happens
Greetings. Matthias
PostPosted: Fri Jun 16, 2017 12:49 pm
How long have you had the amplifier? When did it start having this problem?
PostPosted: Fri Jun 16, 2017 1:54 pm
Hi about 2 years ago, the amp never left my home, very little use. Since yesterday is bad. Only is on the led of the channel indicator
PostPosted: Fri Oct 13, 2017 10:36 pm
I have been having a similar issue with a mini rec
Amplifier works fine on both power modes until 5 minutes pass and the relays just shut the 10 W mode off from the clean channel and red channel., However the clean channel works on the 25W mode but no sound from the red channel.
I've contacted Mesa support with no response.
I already ruled out that the issue was not a bad pre-amp or power tube or any broken solder joints. It seems that the switching matrix has issues with its voltages cause i can hear the relay "popping" later on
Anyone would provide an schematic to debug this issue (i'm an EE) since there is no official customer support in my country (Chile).
