It is currently Wed May 23, 2018 12:19 am
PostPosted: Mon May 22, 2017 10:43 am
Hi guys, i'm continuing to be blown away by my Mini Rec, but struggling slightly with boosting volume for solos.
Currently using a 6 band eq pedal in the loop set flat with the level raised to the required amount.
Only problem is it sounds very muffled and doesn't really let the guitar 'jump out'. I'm going to try cutting the bass sliders (didn't thing of doing that last night) but is anyone using an eq to do the job? Or another pedal like a clean boost?
Thanks.
PostPosted: Mon May 22, 2017 5:28 pm
I used a variety of clean boosts, like the Micro Amp and Mini Spark Boost (love that one).
It's quite possible that your EQ pedal loses highs or is not flat. It may also be a bit of a comb filter. I'd definitely try for a clean boost pedal. In the interim, rolling down your lows (below 250Hz) and pushing up 750Hz works great for leads.
Mini Rectifier blue LED
2x Recto 2x12 Vertical
PostPosted: Thu May 25, 2017 11:07 am
Thanks Elvis, i'll try the eq with the settings you recommend, failing that i'll pick up a mini spark boost.
PostPosted: Thu Jun 01, 2017 7:48 am
Worked a treat by cutting the lows and boosting the mids slightly. I think i'm still going to go for a TC Spark though, the sliders on the eq move around too easily.
