RKII Which FX Loop To Use?
paulg2uk
Post by paulg2uk » Sun May 21, 2017 7:53 am
Hi guys,
I've often wondered is there any difference in using FX loop 1 or 2 on a RKII? I'm running an axe fx thru FX loop 1 at the moment and all sounds pretty good. Should I be using loop 2 or does it not make any difference?
Many thanks
Paul
peterdenny
Re: RKII Which FX Loop To Use?
Post by peterdenny » Sun Jun 18, 2017 11:31 pm
paulg2uk wrote:Hi guys,
Many thanks
Paul
I dont think it matters. I always used the first loop myself. I believe you can run a different effects into the second one since they are switchable. Try it and find out.
silentbob
Post by silentbob » Sun Jul 30, 2017 7:21 pm
I use the second loop for special effects. Currently, I have an EQ setup with a slight output cut. It's great for when I need to cut volume but maintain saturation. We're big on dynamics live and there are a lot of times when I need to maintain my tone, but reduce the volume to a background level and I can't always trust the house sound guy to be on the ball. Combine that with the solo boost, four channels and a clean boost on the front end, I can't imagine needing anything else to get through a gig.
