Hello, I have a Roadster head I bought used about 2 years ago. I believe it was one of the first built as it has a low serial number.
I run on Bold with all channels at 100 watts during band sessions, 50 watts at home. Tube rectification on channels 1-3, diode channel 4.
I have a TC Gmajor 2 in the effects loop. Ch. 1-3 fx loop toggle is On, ch. 4 is Off.
The amp has worked rather flawlessly and I've loved it since day 1.. a big upgrade over the Rectoverb I was using.
However, in the last couple weeks I've noticed an issue when using channel 3 (modern), the volume is noticeably lower than channel 4 (also modern) even though the volume and eq settings for both channels are nearly identical.
When I engage the effects loop on channel 4 to test, the volume is consistent.
When I toggle channel 3 to diode rectifier, the issue seems to go away and switching between channel 3 and 4, volume is consistent.
My question is, is this the normal function of tube rectification or are the tubes in need of replacement?
How long do rectifier tubes typically last and do they wear down like power tubes or do they work until they don't?
I retubed power and preamp tubes when I bought the amp and again recently in December 2016. The rectifier tubes I last replaced with new when I bought the amp in July 2015.
I'm using 6L6 preferred series (tube store), Mesa 5U4GB rectifiers and the following 12ax7's:
V1 - tung-sol
V2 - mullard cv4004
V3 - gold lion ecc83 standard (china?)
V4 - preferred series (tube store)
V5 - shuguang B
V6 - sovtek lps
Last night I replaced the gold lion in V3 with a spare Shuguang and the volume difference between ch. 3 and 4 seems not as bad as before, but still not as consistent as when using diode rectification on both channels.
I'm guessing that even though the gold lion tube is manufactured in China, it still wore down prematurely in V3.
My last question is, are current production Mesa tubes (not labeled Chinese or Russian) susceptible to wearing down faster in the cathode follower positions v3 and v5? I have a few Mesa 12ax7 I could try in those spots to see if they alleviate the issue.
Thank you for reading and any feedback is appreciated.
V1 - tung-sol
V2 - mullard cv4004
V5 - shuguang B
V6 - sovtek lps
