It is currently Tue Apr 24, 2018 1:51 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Dial rec solo issue
PostPosted: Sun Jan 08, 2017 9:04 am
Hey guys. New to the board but from what I've read you guys know your stuff and nice to boot! Bravo. So the reason I'm here is my buddy had a dual rec solo head that had a few issues. From what I've been told is that he used the amp a while back into a cab that apparently had a bum jack. He was getting no sound and for whatever reason he left the amp on fir another hour. I liked at it and he had burnt diodes in the preamp board so i changed those. I plugged it back in after testing circuits and i still get no sound out of channel 1 and some out of 2. I turned it off before running anything else. He also mentioned that previous to the no sound issue he was having trouble with the solo function sticking on. Amy suggestions? It is no longer under warranty and he left it with a tech who took 8 months to say it had burnt diodes but couldn't get to it...lol maybe he knew there was a lot wrong 't with it? Iol. Thanks guys!
 Post subject: Re: Dial rec solo issue
PostPosted: Mon Jan 09, 2017 10:28 am
Wavey63 wrote:
...... He was getting no sound and for whatever reason he left the anno on die another hour. .......
Welcome to the forum.
I'm guessing you were trying to tell us that "he left the amp on for another hour"?
Have you ruled out bad tubes yet? If he tried to play the amp for an hour without a proper speaker load the output tubes are most likely damaged, and possibly the output transformer as well.
I would bring the amp to a Mesa certified tech, they are listed on Mesa's website.
Good luck,
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
Slinky's & Jazz III's
Voodoo Labs MIDI
==> NOMAD on Facebook <==
PostPosted: Mon Jan 09, 2017 10:49 am
Yeah sorry about the bad post. Lol should i check the tranny to see if it's shot? I'm trying to save my buddy money by repairing it if i can.
PostPosted: Mon Jan 09, 2017 11:11 am
Have you eliminated the power tubes as the failure?
Can you get a signal from the FX loop send?
Dom
'10 Mark V
'74 Les Paul Custom
'95 American Strat
Voodoo Labs MIDI
PostPosted: Mon Jan 09, 2017 11:37 am
I haven't checked tubes. I dont have replacements on hand. I'll check the fx loop when i get home from work.
PostPosted: Sun Jan 29, 2017 8:43 am
Finally got time to look into the amp a bit more. One thing i find questionable is the 2 yellow leafs from the PT that are speed to read at 3vac according to the scheme. One reads at 4.5 and the other 0vac. Is this a bad PT? Should i treat those leads out of the circuit?
PostPosted: Mon Jan 30, 2017 5:12 am
Could you translate this?
There should be three sets of secondary taps from the PT, B+ at approx. 350V, 5V for the 5U4GB heaters, and 6.3V for the preamp tube heaters, switching & pilot lamp.
http://www.freeinfosociety.com/electronics/schemview.php?id=507
I think you are measuring the 5V rectifier tube heater taps. Could you share some pictures?
Dom
'10 Mark V
'74 Les Paul Custom
'95 American Strat
Voodoo Labs MIDI
PostPosted: Mon Jan 30, 2017 6:50 am
Sorry. I'm not sure how to post a pic but both red taps give me 345v. Both green about 3.2v. One yellow gives me 4.5v and the one closest to to rear of the chassis gives me barely. 2v.
PostPosted: Tue Feb 07, 2017 6:54 am
Where is the best place for replacement trannys?
PostPosted: Wed Feb 08, 2017 3:30 am
Www.mesaboogie.com
Dual Rectifier
Recto 4 x 12 Straight v30s
Ibanez RG560
BC Rich Beast (Fully Understand it's namesake now)
"Efficiunt Daemones, ut quae non sunt, sic tamen quasi sint, conspicienda hominibus exhibeant." - Lactantius
PostPosted: Sun Feb 12, 2017 10:45 am
Thanks! How do i treat to make sure it's a faulty tranny before i have my buddy shell out the money for a new one?
PostPosted: Mon Feb 13, 2017 5:07 am
Have you rules out bad tubes yet?
Have you tried sending a signal into the FX return to see if you get sound?
If you suspect the 5U4GB filament supply, remove those tubes and run the amp on silicon diode rectification until you sort out the other issues you have with passing signal.
One thing at a time.
Dom
'10 Mark V
'74 Les Paul Custom
'95 American Strat
Voodoo Labs MIDI
PostPosted: Mon Feb 13, 2017 7:27 am
Nit bad tubes. Amp does same thing in diode and tube rec mode. Not sure what you mean by sending Siddhartha lsignal into fx loop....
PostPosted: Mon Feb 13, 2017 8:15 am
LOL Siddhartha.
If you are not getting signal through the amp, and you have completely eliminated all tubes as an issue, you need to determine if this is preamp or poweramp. Pretty basic stuff. First thing I would do is plug a guitar into the amp, then connect the FX send to the FX return of a working amp and see if you get signal. If yes then you know the issue is not in the preamp. Next you would send audio into the return of the suspect amp, either from another amps FX send, or even an MP3 player to see if it passes audio to the speakers.
BTW- if you look at the schematic for the power supply you will see that the 5U4GB tubes are always in the circuit regardless of the rectifier select switch. This is why I recommended pulling the tubes and selecting diodes. If there is an issue with that TX secondary it could be pulling down other voltages.
Dom
'10 Mark V
'74 Les Paul Custom
'95 American Strat
Voodoo Labs MIDI
PostPosted: Mon Feb 13, 2017 12:44 pm
Ah...now i see...ok. and sorry for the auto correct issues....lol wth is Siddhartha?
Users browsing this forum: Bing [Bot] and 2 guests
cron
