afu
Some may have noticed how Modern mode barely bleeds through when the MV or Output is all the way down. Recently I found that turning the Presence up removes the bleeding, until completely gone at full up.
Not yet sure why, yet, but my first guess would be leaking on the relay to switch the Presence over to the feedback/PI for Vintage. If true, a tiny bit of signal goes to V5b. Otherwise something else in proximity to the Presence pot ground is doing it.
I'm pretty ill and sore, so if someone else gets the urge to check that, that would be groovy.
