Dual Rec Multi Watt how do you put a LED inside of it???
mesastrategy500
http://www.thegearpage.net/board/index.php?threads/anyone-know-how-to-put-a-red-led-inside-a-mesa-dual-rectifier-is-it-complicated.1754758/#post-22828549
i posted this too......
just wondering what the best way is to go about putting RED LED inside a big dual rec....... the guy says he used something at first in the video but then switched to a smd light strip and taped it to a lgiht bulb??? any thoughts??
im not a hands on tech guy i need things to be as simple as possible.......
This may not be the way you want to do it, but the easiest, quickest, and safest way to do it would be to get an LED strip for a computer like this https://www.amazon.com/gp/product/B00NQR7R32/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1. Then wire it to a 9v adapter like this https://www.amazon.com/gp/product/B005CMP434/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1, then a wall adapter, like this https://www.amazon.com/gp/product/B00CP1QLSC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1, or you can run a 9v battery with one of these https://www.amazon.com/gp/product/B005D65LEG/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
I did this to a Marshall and it looked awesome. The downside being that you have to use an additional power outlet for the light, or connect a battery, so it won't flip on when you turn the amp on. The upside being that you don't risk zapping yourself going into the amp AND you don't have to tap into the amp's power supply thus there is no risk of hum, hiss, squeal, or anything else.
