Mini Rectifier revisions
WMHaze
Post by WMHaze » Fri Sep 30, 2016 12:41 pm
silverwulf's post regarding the 3 channel non-multiwatt Dual Rectifier guide got me thinking and looking at the Mini Rectifier to see if it has subtle differences. And sure enough there are.
The major one I can see is the FX loop hard by-pass switch. Some mini recs have them while others do not.
I'm not sure as to which version is earlier vs later though.
I wonder if there are circuit board revisions as well?
elvis
Re: Mini Rectifier revisions
Post by elvis » Fri Sep 30, 2016 7:24 pm
The original had the switch, the later versions do not. Instead the FX Send jack is a switching jack.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Addictedtokaos
Post by Addictedtokaos » Sun Oct 02, 2016 3:06 pm
the original Mini Rec 25 included the FX switch giving you the ability to bypass the FX loop circuit and tube. There was a video on Youtube where Randall Smith explained how they added it so if the player wanted to ability to clean up the signal slightly/slightly different tone..., but found most players preferred it with the FX loop switch on whether they had fx plugged in or not. My guess is it was something they thought was a nice touch never really was used and phased out on the later models.
I believe the original has the switched input jack in addition to the FX circuit switch.
FYI, mine has been set to ON since I bought my mini rec in 2012.
ESP Eclipse II w/EMG JH Set
Squier Bullet w/SD SH-2n/SH-6
Mini Rectifier
2x12 Horizontal Cab
Line UX6 w/ Overloud 2
sonoragazzo
Post by sonoragazzo » Mon Oct 10, 2016 11:12 am
elvis wrote:The original had the switch, the later versions do not. Instead the FX Send jack is a switching jack.
This is correct, new versions do not have the switch and the FX loop is automatically off if there is nothing inserted into their 1/4 loop sockets.
