Rectoverb Series II Effect Loop Modification
cyber104
Hi All:
I would like to do this modification to my Series II Rectoverb. The post indicates that this modification will allow you to toggle between "Series" and "Parallel" effects loops.
The author refers to a 3PDT switch - but what is shown is a 4PDT. I'm thinking he means that it can be accomplished with a 3PDT because the 3 leftmost lugs are unused on the 4PDT.
I guess my question is (since I'm good with a solder iron but not an electronics genius) - can I simply use an "on/on" 3PDT switch and wire it up exactly like the below picture - simply ignoring the leftmost group of 3 lugs? Currently the OP has nothing connected to those lugs.
Here is a link to the original post for your review: http://forum.grailtone.com/viewtopic.php?f=4&t=26702&start=15
