Hey
I picked up another Recto to accompany my Rev G dual. Its a 3 Channel Triple rec (non-multi watt).
I noticed immediately that vintage mode is a lot darker than on the 2 channel. Modern is still very bright and quite similar to the 2 channel, but there seems to be a vast difference between Vintage(and Raw) compared to Modern on both channel 2 and 3 on the Triple rec itself.
Part of the charm of vintage mode on the old 2 channel is that dropping treble below 12'oclock boosts mids rather than cutting much more top end and doesn't make it dark and woolly (great on low gain settings) - overall brightness of the channel can then be dialled in with presence.
But on the 3 Chan recto dialling down the treble in the same way results in a VERY dark tone.
Is this normal?
Is this normal?
