tremoverb tubes ...help!
tremoverb nick
UK
My tremoverb has never sounded as good as it did since the first tube change.
The output tubes were str420.
What do you recommend folks?
Also - how do I know what colour dot tubes my tremoverb requires?
I'm pretty sure the original str420 were yellow dot.
If I recall correctly my Tremoverb back in the day had the 6l6gc. I think the current revision of those is STR-440. You can google the color codes but my rk had gray, i got green and i couldnt really tell a difference. I also have had good experience with the Electro Harmonix 6l6GC. Just get a matched set. I got mine from Amplified Parts and Im quite happy with those guys. Tell em your amp model and they can help you dial in. A lot of people like the Winged C that were in my Marshall if you need an EL34 and I agree those sounded really good. The Mesa ones will be totally good as well but I dont remember the current model number.
PS did a quick google and found this:
Red/Yellow...earliest breakup. Equivalent to Groove Tubes rating of 4
Green/Gray...medium breakup. Equivalent to Groove Tubes rating of 5
Blue/White...latest breakup with most clean headroom. Equivalent to Groove Tubes rating of 6.
