I try to figure out what is the cause; when it comes to suddenly loss/cut off in volume and only moderate audible hum dominated the sound in all channels. I try to measure the dc voltage in the plate of the phase inverter tube with the dmm, comm touching the ground/chasis and the other lead to pin 1 (and pin 6) of the 12Ax7 and a strange happen, the hum just gone away, the amp back sound normal again, same thing when i measure the 30uF/500V cap or just flip the stand by switch off and on again (those action can made the hum gone). What is really the cause of this? Is the particular tubes failure (CF or PI)? OT issue? or something with the filter caps or the the .047uF/1 KV? I measured all the component values, the B+ supply, the bias, and all the DC supplies at the point A, B, C, D, E (as in the schematic); and all of them just seems to be OK. Can someone help to tell what is the cause of the problem?
