Hello
I've been toying with the idea of using an attenuator (probably Koch LB-120) with my dual rec. I'm just wondering if it would do any good for me.
Mainly I run my Ch3 modern master volume at about 9-10 o'clock, and Ch2 vintage about 1-2h later . FXloop bypassed. Gain usually at 1-2 o'clock. Sooo it's in the "manual recommended" range.
Considering all the "cold bias/clean power section/dominating preamp gain" thing I'm seeking opinions as to whether increasing MV with an attenuation would really be beneficial for DR. Additionally some air probably still has to be pushed to sound anything near good so I'm not considering complete neutering of the amp. Just - would it be that much difference between Ch3 modern MV 9o'clock and i.e. 1-2o'clock with some attenuation.
What is your experience with using attenuators? How high do you run your rectifiers when playing alone, outside the band context?
