I am preparing to restore a heavily mutilated Dual Rectifier head. It will be necessary to replace some components on the main PCB, and I do not want to damage any traces or lift any solder pads. My soldering tool is a Weller WLC100 station. I have lots of experience building and repairing PTP amps, eyelet boards, and single sided PCB designs. However, I do not have much experience working on plate-thru Mesa boards. Any information, advice, tips, tricks would be greatly appreciated... best soldering/desoldering techniques, recommended iron heat, tip size, best process of removing radial caps, etc. The objective is to make this amp look factory fresh inside and out.
