Installed: Roadster CH2 BRIT Mid Scoop Mod - Video
Golden1984
I just installed additional mid-scooping tone stack for BRIT mode.
It was kinda useless for me because of too much mids...
https://www.youtube.com/watch?v=IRcn6tRroj4
Sounds good.
How about sharing the details of this "mod"?
Dom
Here it is:
http://www.gonerjenny.com/files/TS.jpg
No need to touch mainboard. Just put it before CH2 MASTER POT.
It works just like a 3 band EQ from CH3&4 all set to 12 o clock. Even in that position it cuts away lots of middle. You can change resistor values to get different EQ curve, but I found it scooped enough in zero position. CH2Brit has also less drive stages than Roadster`s channels 3&4 so it`s original tone stack effects overall tone shape a little bit more than it does in Lead channels of MARK series amps.
I also installed a relay switch connected to clean/fat/brit miniswitch to engage this additional tone stack only for BRIT mode and bypass it while on clean&fat modes.
Greetings!
