Southdakota
- Joined
- Mar 30, 2016
- Messages
- 9
- Reaction score
- 0
Hoping this is a common problem and someone will have some advice. My 2010 Roadster head has a reverb problem. When I channel switch from either 2, 3 or 4 to channel 1, I get a really heavy dose of reverb for about 1-3 seconds and then it tapers off to the normal level that I have it set to, which is about 10 oclock. It does not happen when switching from 1 to any of the other channels.
On another note.....regarding the Fx Loop on footswitch. The pedals in my effects loop are staying engaged wether the Fx Loop switch is on or off on the footswitch. It's not a big deal to me as I have one pedal in my effects loop that is an always on pedal and therefore I would have it engaged all the time anyway. Just not sure if this is normal? I do have the effects loop switch in the back of the amp engaged. Thanks for any advice I can get!
