goldenGeek
- Joined
- Feb 27, 2015
- Messages
- 16
- Reaction score
- 0
I'm relatively confident with point to point amps, but now I've got a Mesa Single Rectifier (series 1 (rev e, I think), solo 50) on the bench. I've worked little with PCB-base amps before, but this seems fairly okay because all pots and connectors are wired off board. Now to the problem - theres some irritating hum in the amp. I've replaced all tubes (with new ones) and the noise got better but the hum is still there. It's specially noticeable in the clean channel and really bad when the clean channel is turned to "pushed" mode. But even if I turn down the master volumes the hum is still present, way too loud to be okay. So I've chopsticked a bit around in the amp an found that poking the wires comming off the clean channel gain pot is awfully microphonic, almost like tapping a microphone. This does not happen on the second (overdrive) channel, which is kind of weird because theres a whole lot more gain going on there.
I must add that when I got the amp the fuse was blown and the output tubes was bad. Can this be the output transformer causing the noise? Is there a way to measure the OT without replacing it? Also, there's some burned PCB around the rectifier-diodes for V1-heater which seems to be fixed with new diodes way back. Is that where I should start replacing parts? Or should I start in the other end since the hum is there when the master is down and nothing is plugged in?
