Armando
Hello,
I just want to know if this is "normal" or issue. I have a series I Road King head I use with the King Kontroller. When I adjust all individual Master volume levels, I see that channel 4 needs to be set quite a bit lower than say Ch 3(1 & 2 also). For example, I have the master for channel 3 set to 11 o'clock and have to set channel 4 to 7:30ish just to roughly match channel's 3's level. Both channels 3 & 4 are set to 50wt(2x6L6) and Diode as the selected Rectifier type.
Can any RK owner varify that this is either normal operation or that something is definitely wrong here.
Thanks in advance!
Thanks in advance!
