Congrats on your amp. I have owned a maverick head for about 10 years and really like it. I'll try to answer some questions but I'm not a repair guy....I just play the **** thing, but I can try and help until somebody more knowledgeable chimes in.
bleachedfan said:
1.this amp has been sitting for a while, anything I should do?
Not sure how long "a while" is. You might consider having a technician go through the amp, especially since it sounds like there might at least be an issue with the reverb. Mesa has an authorized repair search feature on their website.
bleachedfan said:
2. There is a slight hiss with nothing plugged in.
It's really tough to say just without having the amp in front of me. Does it hiss on either channel or just one? If the output knob is turned up high enough, it's normal to get hiss even with nothing plugged in. If everything is turned down, or it's on standby, and there's a hum then maybe something is up. Humming could mean a capacitor problem, but it's usually not a high pitched hiss. But there's also a fan in the amp and sometimes they get noisy, make sure it's no that that you're hearing (should be obvious).
bleachedfan said:
3. The reverb buzzes when turned up.
That seems strange. I'd guess it's either the reverb tank or the tube driving the 'verb. It's the 5th preamp tube for this amp (looking at the back of the amp, it should be the 2nd from the left....tube 1 is closest the the input jack). Try swapping another preamp tube (if you have a spare you know works, or borrow one from a working amp) in this position and see if that helps the buzz. Any 12_7 will work.
bleachedfan said:
I was also wondering if anyone had info on how to do the 1m mod for the input. I have some experience with fender amps, but those are a different beast.
I'm not familiar with this mod, sorry. You can find schematics here, probably good to have.
http://www.freeinfosociety.com/electronics/schemview.php?id=288
Good luck!
