guitarslayer
At the moment I'm using Winged C 6L6, JJ hand picked 12AX7s and EH 5U4GBEH (I use the diode mostly). Sounds real good. What tubes are you guys using? Do you guys have any suggestions for a great set for the metal player?
if your using stock preamp tubes that will cause the muffledness, every tube in the line will effect performance in one way or another. keep rolling the rest till you eq it just rightknotts said:I just dropped in a Tungsol 12AX7 in my roaster on Sreamingdaisy's advice on a separate thread and I have to say overall, I'm pretty impressed with the difference. I think i was hoping that I would be able to turn the bass up a little and turn down the treble and presence a lot, but it definitely cut down on the muffled sound. I still have the bass way down and I did cut the treble a little across all channels, but it's definitely the right choice. I think the change is most noticeable on channel 3. I originally steered away from the vintage mode because it seemed muffled before, but now it's bright and cuts through the mix. I think that it also takes my xotic AC booster better. It sounds great for blues and rock and then there's channel 4 for when I want to take it over the top. My current bass player said it's the best sounding mesa he's ever heard, and I trust his opinion.
I am thinking about dropping one in my LSC as well. Overall I'm very pleased.
ken361 said:if your using stock preamp tubes that will cause the muffledness, every tube in the line will effect performance in one way or another. keep rolling the rest till you eq it just right
Enter your email address to join:
