2 channel DR not loud enough
dbsens03
Post by dbsens03 » Thu Jun 14, 2012 10:22 am
I'm being blown away by a Marshall 2205 being run through a mesa cab. I"m stuck using a 1960A cab. EQ suggestions?
"Music is worthless unless it can make a complete stranger break down and cry."
"There are only two kinds of music; music that sounds good, and whatever you want to call that other stuff."
Si.
Re: 2 channel DR not loud enough
Post by Si. » Thu Jun 14, 2012 4:59 pm
Mids, mids and more Mids...
Marshalls are very mid orientated amps and as such cut through really well, much better than Boogies IMHO.
screamingdaisy
Post by screamingdaisy » Thu Jun 14, 2012 5:24 pm
Marshall's tend to be fairly mid heavy amps that cut through easily, and the Mesa cab is loaded with V30s, which also produce a lot of midrange
Rectos are capable of sounding fatter and when dialled in to sound fat they don't cut through the mix. Combine that with a set of scooped sounding G12T-75s and you're pretty much f*cked.
If you want a Recto to cut through you need to lean out the bottom end and make the amp brighter than you would typically dial it in on it's own. The presence knob is your friend.
And see if you can talk the other dude into swapping cabs.
94Tremoverb
Post by 94Tremoverb » Thu Jun 14, 2012 6:59 pm
What screamingdaisy said - it's the cab. The speakers in the Mesa cab will be either V30s or C90s, which are both 100dB speakers with strong midrange (higher mids for the V30, lower mids for the C90). The speakers in the 1960 will be G12T-75s which are 97dB speakers with a hollow midrange. That means that the 100W Mesa amp has its power effectively halved and the 50W Marshall has its power effectively doubled, relative to each other in the mix.
You need a better cab, or to change the speakers in that one... if you can't persuade the other guitarist that his Marshall belongs with a Marshall cab and his Mesa cab belongs with your Mesa amp :).
Blaklynx
Post by Blaklynx » Thu Jun 14, 2012 9:47 pm
Both these amps need a divorce from their cabs. Swap them.
I laughed when I read that the Marshall is with the Mesa cab and a the Mesa with a Marshall cab. It's just ironic. It like a wife swap thing. :lol:
Gotta love tubes!
If you're interested in the chicken head knob replacement on my Roadster amp, go here:
http://forum.grailtone.com/viewtopic.ph ... 98#p476098
dbsens03
Post by dbsens03 » Fri Jun 15, 2012 12:52 am
ya, I need to buy a mesa cab. Fixed the volume issue though.
boss4
Post by boss4 » Fri Jun 15, 2012 3:19 am
Mesa's to play alone are fun and f%&#!ng heavy but when it comes down to integrate the sound in a mix and it haves to cut through the all instrumental... More mids, less bass, less gain, overdrive pedal... But when we can do it, nothing sounds like it!
Mesa Boogie Dual Rectifier 3Ch
Mesa Boogie Recto Cabinet 4x12 Standard
Bogner Alchemist
Gibson Les Paul Standard
Ibanez RG2550Z Prestige
APEMAN
Post by APEMAN » Fri Jun 15, 2012 8:09 am
Hi,
=> Could be the power tubes too! DR 2CH? How often do you play? How old are the power tubes? Normally you don't have trouble with that Marshall when it comes to loudness.... (as long as you don't zero the mids!)
By the way, I'm fully behind that speaker theory - but before you start looking for another cab/speaker I would try to be shure that my amp works right.....
markblasco
Post by markblasco » Fri Jun 15, 2012 11:19 am
The issue you are having is masking, not volume. The other amp is masking yours. Your amp could be putting out twice the volume, but if it's full of bass and low mids, you still won't be heard, especially with a bass guitar in the mix as well.
Try turning down the bass on your amp, turning up the treble and mids a bit, and maybe presence. It may not sound as full as you want my itself, but it will work better along with other guitars. Definitely do this before buying new speakers, it may work for you. if you don't use your FX loop for anything, you could also get an EQ to put in the loop, which would allow for a more detailed adjustment of the sound to help it cut through more.
dbsens03
Post by dbsens03 » Fri Jun 15, 2012 11:41 am
I turned the bass down to about 10 o'clock. mids and treble are between 1 and 2 o'clock. presence was about none and gain goes between noon and 3. But it was set to vacuum tubes. When I switched it to diodes it got way louder. I know it needs to be ran thru a mesa cab. And i'll be getting one but at least I can hear myself clearly now. As for the tubes. I'm not positive how old they are. I picked it up last year through a trade on craigslist for a nomad. He said he hadn't been using it too much though and that the tubes were fairly new. I think I may just put new tubes in before long anyway though. What are some favored el34's for the 2 channel DR's?
NOWAYBACK
Post by NOWAYBACK » Fri Jun 15, 2012 2:13 pm
Hi!,
Cab-wise, a good step forward and with a relative small investment would be to replace 2 of your cab's G12T-75s with V30s, in an X pattern. Just be sure the impedance of your new speakers is the same as your old ones, they are 16 Ohm most likely if it's 4x12 1960A.
Best,
Marcelo
ESP Eclipse II (SD JB/Jazz), Schecter C1 (JB/Jazz) & Blackjack (Blackouts)
Mesa Mark V, Marshall JVM 410H, 2010 Recto
Marshall 1960 BV(V30s); 2x12 with V30/G12-T75
TC GSharp - Maxon OD808 - Fulltone Wah - POD HD500
http://www.nowaybackrock.com
screamingdaisy
Post by screamingdaisy » Fri Jun 15, 2012 3:38 pm
dbsens03 wrote:What are some favored el34's for the 2 channel DR's?
SED Winged =C= seem is a favourite, but they doubled the price of them a year or so ago and I don't think they're worth it anymore. I find them a little brighter and skinnier than the stock Mesa EL34s, which I believe are still Electro-Harmonix. Call me weird, but I have a quad of Winged =C=s sitting on my shelf as spares because I like sound of the stock Mesas better.
That said, when it comes to Rectifiers I really like the JJ E34L. It gives you much of what is good about an EL34 without giving up quite as much bottom end in the process. I prefer 6L6s in my Recto, so my opinion is going to be slightly skewed towards that tone.
Heritage Softail
Post by Heritage Softail » Fri Jun 15, 2012 4:12 pm
I have ran JJ's and SED. JJ's are really pretty good for the $.
For practice I like more thump. Jamming needs less bass, less gain, and more punchy mids.
The bass player has the low end covered. IMO, if the guitar player does not bring the pain in the mids, things lack clarity and punch.
YMMV
Mesa MK IIC, DSL100, Dr Z Maz 38 NR, Bogner Uberschall Twin Jet purple mod, 5153, Rectoverb S2
JP6, LP, SG, Anderson Pro-Am, Suhr, PRS, Strat, Tele, assorted victims of pentatonic hacking.
Gone - MKV, Single Rectifier, Rivera K-Tre
18 year chip.
ryjan
Post by ryjan » Fri Jun 15, 2012 5:23 pm
In bass/low-mid heavy amps like the Recto the EL34L's will get really loose and flubby. Try the Ruby EL34BHT out. They are cheaper than the SED's and have great clarity and are very durable.
Mark V:25
Recto 2x12
ESP Explorer
dbsens03
Post by dbsens03 » Fri Jun 15, 2012 8:00 pm
how about favorite 6l6's? Not sure which route I'll end up going.
