WannaBoogie
i know I read about this issue here before. But, I cannot find it in a search...
When using the effects loop on my DR3Ch (2011), the volume will drop to almost zero... Then after a few seconds... it will come back up.
My feeble memory recalls that it must be a preamp tube (at V4 or V5??). Should I crack it open an start rolling tubes? Or is it likely another issue at play here?
This one still has the stock tubes in it. But, I have a nice assortment of 12AX7's (Tungsol, phillips, and Russians) to play with.
Cheers
Cheers
