Want Pre500 tone? Here's how to get it!
afu
Re: Want Pre500 tone? Here's how to get it!
Post by afu » Sat Jan 24, 2015 2:37 am
Regarding the 100 ohm resistors under the cathode bypass cap:
The resistor alters the gain of the stage. The DC voltage "sees" 1.8k and 100 in parallel = 94 ohms. Gain boost is reduced from a circuit with 1.8k and 1uf to ground.
The resistor also alters the corner frequency for the gain boost. AC voltage "sees" 1.8k and 100 in series to the cap. The gain boost affects frequencies over 83.8 Hz (vs 88.4 without it).
It's called a cathode boost limiting resistor, IIRC. In this case, removing the 100 ohms would alter the gain boost much more than the corner frequency.
My personal opinion would be to leave the one on stage 1 alone if you want a clean sound that's clean. Since the tone stack follows it, the treble, presence, and gain controls for CH1 should cause breakup and overtones much earlier than the stock setting, were it removed.
My Humble Music Tech Blog:
Dual Rectifier Index
bjorn218
Post by bjorn218 » Sat Jan 24, 2015 2:47 am
I cannot believe I was such a slacker I never got around to uploading a recording.
This is a scratch track I made for my drummer to lay his tracks down to. Forgive the beep as It is hard coded in the mp3 for him.
https://soundcloud.com/lasanche/hell-correct
We did this a few weeks back. Running my Ibanez DT-250 into my Dual with mods I made from this thread. No changes to the amp since I last posted. I think I was actually running the Orange channel for this recording.
Amp settings Pres: 11:00, Master: 1:30, Gain: 11:30
Bass: 12:00, Mid: 1:00, Treble: 4:00
Guitar has single volume, no tone control, Dimarzio Megadrive pickup.
In September I had decided to stop down tuning to B which we had been using since 2013. I had grown tired of trying to figure out how the guitars and bass can play nice with each other at that tuning. After listening to all the stuff I loved when I was growing up. the music that really moved me and made me want to play this style and after listening to my holy grail heavy tune Slowly We Rot and finding out it is in standard tuning, I tuned back up to standard tuning. That doesn't fit my voice so we dropped it down a half step, now all guitars have their space. My bassist has even started using distortion on his bass, which I had always hated before, but it actually compliments the guitars right now.
Dual Rectifier
Recto 4 x 12 Straight v30s
Ibanez RG560
BC Rich Beast (Fully Understand it's namesake now)
"Efficiunt Daemones, ut quae non sunt, sic tamen quasi sint, conspicienda hominibus exhibeant." - Lactantius
Shemham
Post by Shemham » Mon Jan 26, 2015 2:48 pm
I finally got around to make some clips of my modified Multi-Watt DR.
nearly two years ago I made the following changes: 1) jumped the 100 ohm resistors 2) added 5M5ohm Resistor in parallel to the 680k resistor in the first filter section to drop the total resistance to Rev C/D values.
Here you can find link to the clips:
http://www.tonefinder.com/index.php?sec ... ue=shemham
Basically I recorded two clips in Vintage and Modern modes practically everything set towards noon. Then I made one fine tuning to Modern settings and used my standard settings for another Vintage clip. I tried to make the clips very plain to demonstrate the actual tone and texture of the modified amp. I use a clean boost to bring my guitar signal to moderate levels as I'm using fairly low output pickups. Anyway, you can find most of my settings and gear used behind the link.
kramerxxx
Post by kramerxxx » Tue Jan 27, 2015 3:00 pm
Shemham wrote:I finally got around to make some clips of my modified Multi-Watt DR.
Hi,
What does this do to the sound/feel of the amp?
I've done the 100 ohm resister jumpers, that made the amp more present.
afu
Post by afu » Tue Jan 27, 2015 9:44 pm
I really like the tube/modern one. The other one is really good, too. All of the dirt channel recordings sound good.
LesPaul70
Post by LesPaul70 » Wed Jan 28, 2015 7:37 am
Shemham wrote:Here you can find link to the clips:
Wow, that sounds good. Especially the 50W channel 2 Vintage sound, awesome tightness, it's pure hot-rodded Marshall from hell! :twisted: The 100W samples aren't bad either, just a little mushier.
The samples are pretty close to what my C sounds like, esp. the tightness of the 50W sample. The main audible difference I can discern is the different top-end character - the highs of your modded Rec sound more saturated, or somewhat "wetter" (for the lack of a better word). I guess the different transformer might play a role in this. But otherwise, it (again, especially the 50W sample) is very close. You can consider your mods a success - and I believe that the EL34s help also in the tightness department.
Shemham
Post by Shemham » Thu Jan 29, 2015 10:18 am
Thanks for the comments.
kramerxxx wrote: Hi,
Installing the 5M5ohm resistor parallel to the 680Kohm resistor equals to removing the 2M2ohm/82pf circuit and replacing the 680Kohm with a 470Kohm resistor except it does not influence Raw mode at all. 82pf cap is so small that it should be insignificant with the 0.0022uf cap there.
Tone/feel wise the change is quite subtle. I get more gain, with more mids and lows. In other words, it makes the tone a bit fuller and I find it useful for leads. It's still something pretty minor. If you have changed the gain pot value, that will yield much bigger change and makes the change even less noticable. I didn't like the higher value gain pot and deciced to stick with standard Rev C/D specs.
Alternative method is to change the 2M2ohm resistor with a 1M5ohm which will give same resistance as Rev C/D in Vintage and Modern modes while adding more gain to Raw mode.
LesPaul70 wrote:Wow, that sounds good. Especially the 50W channel 2 Vintage sound, awesome tightness, it's pure hot-rodded Marshall from hell! :twisted: The 100W samples aren't bad either, just a little mushier.
Haha! Thanks. Yeah, it's kinda Marshallesque. It's what I use for both my rhythm and leads normally.
I actually tried 250kohm presence pot with Modern mode once. It (at least seemingly) tightened the lowend even further as you're likely to dial your presence higher, but that was way overkill and made the mode a bit too brittle IMO. But yeah, some of the differences with the highs might be related to different output transformer, although you already confirmed that Rev G does not sound like Rev F through Rev C's power section so there's likely something else going on with Rev F's preamp.
JCDenton6
Post by JCDenton6 » Thu Jan 29, 2015 5:00 pm
bjorn218 wrote:I cannot believe I was such a slacker I never got around to uploading a recording.
That sounds really good guys!
These clips are pretty much nailing the tone on Rev C clip:
https://dl.dropboxusercontent.com/u/473 ... 00-6L6.mp3
B.C Rich Guitars
Mesa Amps/Cabs
wulf
Post by wulf » Sat Jan 31, 2015 10:00 am
wow - awesome tone.
what amp version do you use, and what mods have you done?
as far as I have read here in this board, you have tried some different mods. so - which mods are responsible for this tone?
JCDenton6
Post by JCDenton6 » Sun Feb 01, 2015 3:10 am
Thanks, I'll PM the mods to you.
B.C Rich Guitars
Mesa Amps/Cabs
JCDenton6
Post by JCDenton6 » Fri Apr 10, 2015 3:56 pm
I found more anomalies that I have previously overlooked: R503(?) and R361-R362(100 ohm) , which I didn't find on the schematics and is soldered in Rev C, D, E, F and up into the early serials of Rev G.
I didn't see this on later Rev G's...
Might have to download for full size pics.
Rev C: https://www.dropbox.com/s/hglqdm9uiiek2 ... 4.jpg?dl=0
https://www.dropbox.com/s/1eglwvt1py492 ... 4.jpg?dl=0
Early Rev G: https://www.dropbox.com/s/yr7ozypwv6bdv ... 3.jpg?dl=0
My Rev G Triple without R503 and R361-R362: https://www.dropbox.com/s/ixsx9v8x9xefq ... 3.JPG?dl=0
https://www.dropbox.com/s/z12xmcnqe8ddn ... 7.JPG?dl=0
EDIT: Finally found the full 2 ch schematic, So apparently R503 is a 220 ohm 5w wire round resistor that was used in the LDR power supply in early models.
R361-R362: They were used to reduce hum when the tap off of the PT was soldered in a different place in the older amps, the Rev G's setup like mine have a tap running of the PT and is soldered right before the LDR power supply, nothing to do with tonality.
B.C Rich Guitars
Mesa Amps/Cabs
mat.corona
Post by mat.corona » Sat May 23, 2015 10:34 am
I've revamped the Lasse & Mago DI after the pre 500 mod. Sounds Huge in my opinion. What do you think? https://www.youtube.com/watch?v=yi7Gwa7PosA
JCDenton6
Post by JCDenton6 » Sat May 23, 2015 10:53 pm
It sounds great, you can hear the characteristics of the pre 500 rectos in the clip.
B.C Rich Guitars
Mesa Amps/Cabs
Shemham
Post by Shemham » Sun May 24, 2015 2:07 pm
Yeah, that does sound huge no question. I'd still like to hear the amp without the OD-808 slamming the front end.
wolf
Post by wolf » Wed May 27, 2015 11:33 am
hey guys...I just recorded another short clip of my modded recto...
https://soundcloud.com/wolfernus/sd-liv ... recto-test
Mesa Dual Rectifier 2 ch /F revision/
Mesa Dual Rectifier 3 ch
ESP guitars...
