Quick Question.. Speakers - V-30 mix
MatCarfi76
Post by MatCarfi76 » Wed Oct 05, 2011 1:59 pm
OK - first - I can buy 2 celestian V-30's for $150.00 (or 4 with 1 dead for 200.00...lol).. I have a marshall 1960A slant - stock speakers (I think g-75's?)- I am thinking of buying the 2, and doing the X pattern in the Cab - which is what I use for my Mesa Triple Rec... ANy suggestions or comments on this sound - also, novice here - is switching out speakers hard....???????
kick6
Re: Quick Question.. Speakers - V-30 mix
Post by kick6 » Wed Oct 05, 2011 2:09 pm
Physically switching them out is fairly easy. Getting the wiring right so that it provides the right load (ohms) the amp requires a little bit of math.
MatCarfi76
Post by MatCarfi76 » Wed Oct 05, 2011 2:17 pm
all 16 ohm, so no difference... but do I need to solder? Like I said, never done this....
cheameup
Post by cheameup » Wed Oct 05, 2011 4:25 pm
most speakers arnt soldered in. they just use clips.
Some companies do solder though . I just took some speakers out of an old combo that were factory soldered
mikey383
Post by mikey383 » Wed Oct 05, 2011 5:33 pm
cheameup wrote:most speakers arnt soldered in. they just use clips.
Every Mesa cab I've owned had factory soldered connections. I believe the 5150 cab I owned had soldered connections.
Nonetheless, crimping on a female spade connector isn't hard, and allows for easier speaker swaps.
I prefer V30s over any other speaker I've tried with a Recto. They just seem to fit better.
Guitars:Schecter C-1 Classic, Ibanez RG7321, Epiphone LP Supreme
Amps:70's Earth head
Cabs:Recto 4x12, 5150 4x12
Effects:Digitech GSP2101, Budwah
Past amps '95 Dual Recto, '96 Dual Recto, Stiletto Trident, 3 ch. Triple Rec
cheameup
Post by cheameup » Thu Oct 06, 2011 7:14 pm
there ya go. you learn something every day
94Tremoverb
Post by 94Tremoverb » Fri Oct 07, 2011 12:17 pm
Modern Marshall cabs (apart from the expensive Hand Wired series) use push connectors.
Mesa and a very few (at least outside the boutique market) other companies still solder them. I'd be surprised if Peavey did - they've used push-connectors on every amp of theirs I can remember since the 1970s. If you had a Peavey cab with soldered connections (that you didn't buy new) I would expect someone improved it.
If the cab has push connectors you don't need any tools other than a screwdriver to change speakers. Just be careful you don't poke it through a cone, and remember which way round the wires go on each speaker :).
