In simple terms what is a Rectifier or Recto and what makes it what it is and different from other tube amps?
Is it a single or multiple answer(s) that address my question?
Is it as simple as an amp design that uses the preamp section for gain?
Is it as simple as an amp design that uses rectifier tubes?
I never really gave it much thought and really do not know the answer.
Years ago I went to the local music shop and played Orange, Saldano, Vox, Marshall, Fender, Peavey and other tube amps including the Mesa Boogie Tremoverb.
It just so happened that the owners had the amps (many, many, many, large volume and models) in a succession that put the most expensive and better amps at the end of the line.
Imagine a wall of amps say 200 feet long from left to right. On this wall all different models and makes of amps sitting next to each other in varying configurations of heads, 4x12 and combos.
As you look from left to right the less expensive mass produced amps were on the left and the expensive point to point wiring and hand assembled amps were on the far right.
After hours I finally played the Tremoverb, in fact I compared it against the other expensive amps just to be sure, but from the very first minute the Tremoverb took my breath away.
So I did not know then and do not know now why some people refer to this amp class as "recto sound".
All I knew was that I wanted a tube amp and did not want to push the output tubes to get the gain I wanted, but instead want to have gain at lower stage volumes.
So please explain, and thanks.
