Pics of Serial Mod done on my 2 Chan Triple Rec. HELP!
DarkIntention
Post by DarkIntention » Fri Feb 18, 2011 8:50 pm
Hey guys! New member here. Excited to be a part of the Boogie Board.
So, I finished up the Serial Loop Mod on my newly acquired '97 2 Channel Triple Rectifier. I wanted to post up some pictures just so I can get some reassurance that I did the mod correctly. I figured this would be the best place to ask! Here are some pics:
Before:
After:
Desoldered green wires from mix pot, soldered and taped them together. Removed orange wire from right lug onto the center lug along with the red wire. Complete? Just want to make sure I wired it correct before pushing it!
So, so far so good. Loop works and sounds great with me delay in it. It retains a nice warmth with the DD-6. With the rest of the amp, everything sounds a bit tighter and has a real nice feel so I believe I did the mod right?? haha. The only thing I noticed is that there is no more "Loop" LED turning off and on (assuming because of the disable ON/OFF Loop that is footswitchable).
Thanks in advance guys!
mikey383
Re: Pics of Serial Mod done on my 2 Chan Triple Rec. HELP!
Post by mikey383 » Sun Feb 20, 2011 10:21 pm
That is right.
The LED should still work though, and the loop can still be switched on and off. At least it did on my 2 channel Dual.
Guitars:Schecter C-1 Classic, Ibanez RG7321, Epiphone LP Supreme
Amps:70's Earth head
Cabs:Recto 4x12, 5150 4x12
Effects:Digitech GSP2101, Budwah
Past amps '95 Dual Recto, '96 Dual Recto, Stiletto Trident, 3 ch. Triple Rec
