general lee said:Hi there, I've been lurking on this board for ages and can't find a solution to the same problem. I have a 3 Channel Dual Recto that I bought a few weeks ago (used, it's about 3 years old I think) and my effects sound awful through the loop. My main concern is, if I modify the loop to series, will I loose the fuctionality of the solo and output dials?? I love this amp and it has been my dream to own a DR for the last few years.
I have a Boss GT 10 that I want to use in 4CM config purely for the effects and to use the expression pedal as both a volume control and a wah.
@rivethead, sorry for hijacking your thread
general lee said:if I modify the loop to series, will I loose the functionality of the solo and output dials??
fluff191 said:Yes. Unless you modify the footswitch. Which is also on the above thread I believe.
mikey383 said:fluff191 said:Yes. Unless you modify the footswitch. Which is also on the above thread I believe.
Not exactly. I posted the directions for the footswitch mod, which I found out later are incomplete. There is more than one page for the directions, and I only have the one.
general lee said:mikey383 said:fluff191 said:Yes. Unless you modify the footswitch. Which is also on the above thread I believe.
So from what I've read, I've come to the conclusion that I just do the loop mod, ignore the footswitch mod and I'll still have solo/master functionality. Is this the definitive correct answer??
mikey383 said:That is correct. The mod doesn't affect the Solo or Master volume, since it's in a different part of the loop.
general lee said:mikey383 said:That is correct. The mod doesn't affect the Solo or Master volume, since it's in a different part of the loop.
Sweet!! Now one last request and please don't flame me , can you post the schematic to do it here please? Or is it the same one in the thread that was posted here? Just want to be 100% certain before I start tampering with the DR. Thanks for all the help, they really are monstrous amps.
