Dual Rec Effects Loop
lawrocks83
Post by lawrocks83 » Fri Mar 10, 2017 12:17 pm
Hi All, looking for some advice please before I purchase a Dual Rec. I've owned before but I had a different setup to now. I'll be wanting to use channel 1 Clean/Pushed, Channel 2 Vintage, Channel 3 Modern and a delay pedal in the effects loop for solo's. All 3 channels will be used as rhythm sounds for different songs but what I want to know is, when I engage to FX switch for solo's can it also increase the volume for solo's? I know there's a solo switch but I want to avoid having to step on multiple switches whilst singing etc. If the send button on the back is increased with that increase the output volume when FX is engaged?
Any help is much appreciated
Eevil
Re: Dual Rec Effects Loop
Post by Eevil » Sat Mar 11, 2017 3:25 am
At least in Roadster the send level knob affects level when FX loop is active per channel or not.
You could buy some clean boost pedal and put that in fx loop after delay. That way you could have boost + delay in single button by using fx-loop on/off (if dual recto has fx loop button in footswitch...)
Current:
- Electra-Dyne
- Mark V
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
- Gibson R7 Goldtop
- Custom strat
- Ibanez RG2550Z
domct203
Post by domct203 » Sat Mar 11, 2017 6:24 am
Eevil wrote:At least in Roadster the send level knob affects level when FX loop is active per channel or not.
+1
The send will effect the level regardless. Your best bet is a clean boost as mentioned, or an EQ pedal. For solo's I prefer an EQ as it lets me choose which freq's I want boosted (too much bass and the lower strings get muddy). The MXR 10-band is a great EQ to use in the FX loop.
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
'18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
Voodoo Labs MIDI
==> NOMAD on Facebook <==
