Roadster lag fix
jdurso
Re: Roadster lag fix
Post by jdurso » Thu Aug 27, 2009 3:44 pm
oh man i cant wait to get home from my vaca and try this... it actually makes sense which makes me hate myself for not thinking of it before. good work echoes
_______________________________________
Amps: LSC 1x12
Cabs: Basson 2x12
Guitars: PRS "McBraz" Brazilian McCarty
Pedals: Bogner Uber
jdurso
Post by jdurso » Fri Aug 28, 2009 10:50 pm
got home today and tried it.... what a huge discovery for Roadster owners, the switching is so quick and paired with the rg-16 i'm in switching heaven
Amps: LSC 1x12
Cabs: Basson 2x12
Pedals: Bogner Uber
sekunda
Post by sekunda » Mon Aug 31, 2009 2:40 pm
This sounds like a must-try for me... set my Roadster aside for the Trem-O-Verb. Thanks for the info! Will check it out and get back. :twisted:
M.D.
Mesa Mark V:35 1x12 Combo
Mesa Mark V:35 Head
Mesa Theile 1x12
Mesa 1/2 Back Metal Grill 4x12 (x2)
2000 PRS Custom 22, 2011 PRS Stripped 58
2017 Gibson Standard T SG (x4)
.DuFF.
Post by .DuFF. » Mon Aug 31, 2009 8:05 pm
I guess I'm lucky... got my Roadster last saturday and it changes the channels without any lag...
But....
echoes420 wrote:Couple this with cycling through the channels whilst in standby to eliminate the "pop" and you are ready to rule the road!
Doesn't worked for me...
I cycled the channels in standby, but it still poped up a litlle bit when i changed the channels on high volumes....
Did I do something wrong?
Gibson Explorer '84 Re-issue
Mesa Boogie Dual Rectifier Roadster 2x12
minus
Post by minus » Tue Sep 01, 2009 9:46 pm
.DuFF. wrote:I guess I'm lucky... got my Roadster last saturday and it changes the channels without any lag...
But....
Effects loop, maybe? My delay pedal amplifies the slight pop between the channels making it much more pronounced. Zero pop when its bypassed.
Roadster Head
Recto 4x12 Cab
Ibanez Xiphos
Ibanez RG 1527M w/ D-Activators
Fender American Strat
Boss TU-2, Ibanez TS9, Morely Power Wah,
TC Electronics Nova Delay
.DuFF.
Post by .DuFF. » Wed Sep 02, 2009 8:31 am
minus wrote:Effects loop, maybe? My delay pedal amplifies the slight pop between the channels making it much more pronounced. Zero pop when its bypassed.
I have no pedals on the loop... just a Korg Pitchblack tuner in the Tuner Out.
I'll try hard bypassing the entire loop circuit (using that switch on the rear) to test the amp totally raw...
mcaviel
Post by mcaviel » Tue Sep 15, 2009 3:37 pm
Laskyman wrote:You know- I always had the reverb "on" even though I never dialed any in on channels 3 and 4....that could explain why I never had any lag...
+100
iceman
Post by iceman » Tue Oct 27, 2009 9:13 pm
I noticed on page 15 of the roadster manual it reads
It is normal to experience approximately 1-2 seconds of delay before the REVERB is mixed with the dry signal after switching the REVERB or Channels. This intentional built-in delay prevents both switching noise from the hard bypass relays used to isolate the pure dry signal from the effected REVERB signal, and the prior Channels sound coming through the REVERB in the current Channel when switching. At first this may seem strange, but after a couple minutes in real world situations you will see that it is preferable to the embarrassing alternative of a loud overdriven crunch chord drowning out your beautiful clean passage in the middle of a breakdown
So it isn't a bug it's a feature?
Roadster 2x12
Mark III SRG Blue Stripe
Mark V
RA 100
Triaxis
PortCity 2x12 OS
echoes420
Post by echoes420 » Wed Oct 28, 2009 3:14 pm
I believe they are talking about the delay on the sound of the reverb mixing itself back in... which is to be expected if you ask me.
2008 DR Roadster
2000 DR Rev G
1999 Rectifier 2x12
1999 Standard Recto 4x12
2010 Vox Night Train
1984 JCM 800 2x12(4104)
1977 Fender Twin Reverb 2x12
1995 PRS CE-24
2005 Fender American Std. Telecaster
2009 Fender Billy Corgan Strat
2009 Gibson SG Menace
gradyogle
Post by gradyogle » Sun Mar 28, 2010 9:30 am
Hahaha. I always have my reverb on, anyway. I guess that's why I haven't had a problem.
CM_X5
Post by CM_X5 » Wed Apr 21, 2010 12:53 am
I never knew Roadsters had a lag problem, luckily I never have reverb off on anything. I always need even the slightest amount. Good info to know anyway as I was planning on buying a Roadster head this summer.
KH Guitar Freak
Post by KH Guitar Freak » Thu Apr 22, 2010 2:21 am
iceman wrote:I noticed on page 15 of the roadster manual it reads
It can be a feature that many people enjoy. Several manufacturers such as Eventide themselves have a DSP option on their stompbox and rack processing units (AFAIK) to allow only the dry signal to come through after you turn on bypass, so that your sea of wet signals don't come through. On the other hand, they also offer the DSP+FX option to have the effect trail at the end along with the dry signal after you turn on the bypass. I hope that makes senses...
Also, they have the killdry option which simulate the reverse of that, whereby the dry signal gets cut out immediately after you turn off the effect, only leaving the wet signal to trail at the end...
kryho
Post by kryho » Wed May 12, 2010 12:58 am
my Roadster is still popping when switching tuner out :?
Gibson Les Paul Custom 1975
Fender Strat 68
Custom7
Carvin DC400
Yamaha APX 700
Mesa\Boogie Roadster
Mesa Boogie 50\50
Line6 Vetta HD
Rockman sustainor
TC Gmajor2
BBE Sonic Maximizer 462
FCB 1010
2x Fender Tonemaster 4x12 custom shop
POD X3
MesaMonster
Post by MesaMonster » Tue Jun 08, 2010 1:22 pm
Does this apply to the Road King II as well? I do the channel cycle thing and I don't have any pop after that. I never really noticed the lab before. I ususally stay on one channel for the entire song and then switch in between. I am also doing the RJM Mini Amp Gizmo to switch my channels so that should keep it quiet. I am using the Line 6 M9 to trigger the Gizmo. Smooth and Sweet. :D
Mesa Road King II
Carvin 2x12 cab
Ibanez RG570 Blue
Schecter Hellraiser Black Cherry
Guitar->Morley Steve Vai wah->Fulltone Fulldrive->EHX POG2->Ernie Ball volume->Amp
Effects Loop: Line 6 M9
giantstepjoe
Post by giantstepjoe » Sun Jun 27, 2010 10:34 pm
LithiumZero wrote:Well that explains why I didn't see the problem. Mine has always been on but only dialed up on channels 1 & 2.
Same here.
Rasmus Guthrie Govan
Partsocaster Lollar Imperials
Gibson Pat Martino Lollar Imperials
Gibson Les Paul Special Lollar mini-buckers
Warmoth 7 string
Mark IVb combo
Stiletto Ace 2x12 combo
Rectifier 2x12
Boogie 1x12 EVM
Peavey classic 30
'74 Fender Twin
