Roadster lag fix
Roadster lag fix
Somebody suggested that I should make a new thread so it can be made into a sticky.
I have had a few people confirm that this worked for them also, but I would like to hear from all you Roadster owners.
It is rather simple to eliminate the channel switching lag in the Roadster. All you have to do is leave the reverb button on the footswitch engaged at all times, regardless of if you have reverb on in the channel strip or not. There will still be the lag on the different levels of reverb mixing in, but the amp is actually designed to do that and with good reason. Nonetheless, there will be absolutely no dead spot in sound.
Couple this with cycling through the channels whilst in standby to eliminate the "pop" and you are ready to rule the road!
2008 DR Roadster
2000 DR Rev G
1999 Rectifier 2x12
1999 Standard Recto 4x12
2010 Vox Night Train
1984 JCM 800 2x12(4104)
1977 Fender Twin Reverb 2x12
1995 PRS CE-24
2005 Fender American Std. Telecaster
2009 Fender Billy Corgan Strat
2009 Gibson SG Menace
2000 DR Rev G
1999 Rectifier 2x12
1995 PRS CE-24
- fluff191
- Donating Member
- Contact:
Re: Roadster lag fix
Sticky!!!
Just send Ned a PM and he will make it happen.
Schecter Guitars | Kemper Profiling Amplifier | Superior Drummer | REAPER
Videos: http://www.youtube.com/fluff191
Tunes: http://www.blackmetalbicycle.com
Thanks fluff! I'm on it.fluff191 wrote:Sticky!!!
2008 DR Roadster
2000 DR Rev G
1999 Rectifier 2x12
1995 PRS CE-24
2000 DR Rev G
1999 Rectifier 2x12
1995 PRS CE-24
- Nitrobattery
- Mark IV
- Contact:
I'm glad this became a sticky. I was ready to sell my Roadster before echoes420 told me about the Reverb button trick.
https://www.youtube.com/user/BoyntonProAudio/videos <--- Fun Gear Demos
You know- I always had the reverb "on" even though I never dialed any in on channels 3 and 4....that could explain why I never had any lag...
*Laskyman*
Mesa Mark V head, Mesa Roadking 212 Cab
Fractal Audio Axe FX II
MFC 101 Mission EX Pedal
Zoom HD16/ Peavey Transformer 112
MIJ Ibanez 6's, Suhr Tele, BICH Exotic 10
That's exactly what I was saying in the other thread...could explain why some experienced the lag and some don't. Just from what I've read, it's about 50/50 as to who's had the lag and who hasn't.
Good thing this is a sticky. Headaches relieved for Roadster owners now!
Good job echoes420!
Good job echoes420!
Guitars:Schecter C-1 Classic, Ibanez RG7321, Epiphone LP Supreme
Amps:70's Earth head
Cabs:Recto 4x12, 5150 4x12
Effects:Digitech GSP2101, Budwah
Past amps '95 Dual Recto, '96 Dual Recto, Stiletto Trident, 3 ch. Triple Rec
- Single Recto
Yeah, I always run my amp with the reverb on, I'm sick like that...Nitrobattery wrote:I'm glad this became a sticky. I was ready to sell my Roadster before echoes420 told me about the Reverb button trick.
I wonder if you did bypass the loop and reverb, maybe that might help? Haven't tried that out yet myself...
Thanks! I am going to try this asap. Does it really work?
Although this is a workaround, it is by no means an excuse for mesa.
P.S. Roadster is one of the greatest amps. It's tone heaven...
http://www.myspace.com/utmostcontemptband
Gear:
Ibanez JPM100P2
Ibanez RG1527 with Blaze/Air Norton
Mesa Boogie Roadster head
Marshall 4x12 AV, Marshall 4x12 with Celestion 35's cabs
Gear:
Ibanez JPM100P2
I run my loop bypassed, but I don't think there is a way to truly bypass the reverb.mikey383 wrote: I wonder if you did bypass the loop and reverb, maybe that might help? Haven't tried that out yet myself...
2008 DR Roadster
2000 DR Rev G
1999 Rectifier 2x12
1995 PRS CE-24
2000 DR Rev G
1999 Rectifier 2x12
1995 PRS CE-24
- Mark III
Well that explains why I didn't see the problem. Mine has always been on but only dialed up on channels 1 & 2.
The small lag never really bothered me but I will try this to see if there is a difference, thanks for the heads up.
+1.LithiumZero wrote:Well that explains why I didn't see the problem. Mine has always been on but only dialed up on channels 1 & 2.
Yep, always had mine on for Channels 1 and 2, though I don't use it for 3 and 4. Makes sense why I never had the problem now.
Like a few others here, I've always left reverb on but turned all the way down on 3 and 4, so I never heard the lag. But now I want to go home, turn the reverb off and see if I reproduce the problem.
Don't know why I'm looking for problems - usually they find me just fine. But the more I can understand about this most impressive tone monster, the better.
Cheers!
Cheers!
- Mark III
I can say that I've never had my reverb off... LOL.. that might explain why I don't notice the lag. I tend not to change channels much while playing songs... sometimes when I am practicing I do to see what it would sound like with differing amounts of gain.
Gibson LP STD 2007 Stock
Hamer Explorer w/ZW set
Strat DLX with Dimarzio AT1 and Cruisers
ESP MII DLX EMG 81/85
Mark 5:25
Mesa Mini Recto 1x12
DIY 1x12 Cab with Eminence Speakers
Mesa Metal Grille 4x12 (half open)
Mark 5:25
