3 channel Triple Rectifier Loop Mod.(Parallel to Series)
Freaker
Post by Freaker » Fri Jun 12, 2009 4:24 pm
Hello guys, I'm a new 3 channels Triple Rectifier owner. I need to use my Boss GX700 into the effects loop to get all the different sounds I use. The problem is already known by all of you. Lost of volume, change of tone and a very dissapointing use of effects.
I want to make the series loop mod, but I havent found something directly related to the 3 channel Triple Rect. I would like someone to send me some schematics, and better, some intructions about how to do it. Also I would like to keep the posibility of bypassing the loop, at leats manually. I know about people who have a switch for series or parallel mode. If someone has this mod, please tell me if the change of tone issue(having the loop on and the effect unit on it) is solved or it is still there.
Thanks a lot.
boxcarmonument
Re: 3 channel Triple Rectifier Loop Mod.(Parallel to Series)
Post by boxcarmonument » Fri Jun 12, 2009 10:48 pm
Here's a 3ch Dual Recto before the Mod.
Here's The same Amp after the mod.
Follow the directions and you can't go wrong. Although this is a Dual Recto I believe the same applies to the Triple Recto.
It's the Single that's different from the 3 rectos.
Good luck,
Dave
Gibson Les Paul Standard
Gibson Les Paul Studio 50's tribute Gold top
Mesa Mark III Green Stripe
And thanks to the MIII a EQ, OD and Reverb put back in thier box.
Mesa C90 loaded halfback cab
Freaker
Post by Freaker » Sat Jun 13, 2009 8:30 am
Thanks for the pictures.
And about the change of tone and the possibility of keeping the switch on/off of the loop???? Can you tell me something about this??
Talking about the pictures, what do I do with the three grey wires???
Thank you very much.
boxcarmonument
Post by boxcarmonument » Sat Jun 13, 2009 3:06 pm
The 3 grey wires go to the pot for the line out level. So you can disconnect them from the pot or remove the pot.
Your choice. As far as fixing the sound with effects in the loop it will fix them. Especially if they are digital effects.
Good luck!
Dave
Freaker
Post by Freaker » Sat Jun 13, 2009 5:39 pm
Ok, thanks Mark I. A last question. Is it necessary to remove the three proged things that you say?? What is their function?? I have removed the whole plate where the rear jacks are and I think it can be safer for the amp (due to use the iron solder int the plate),to remove the wires from the pot, and solder the second and third wires together and isolate the first one. And about those three things, I just want to know if it is completly necessary to remove them and do the connection with the jumper wires.
Thanks again
PD: Another question to people who are really into electronics... do you imagine a way to make this mod through a switch?? I mean, change from parallel to series using a switch. I know that a technician here in spain does it, but it's too expensive for me to send the amp and pay the mod cost.
mikey383
Post by mikey383 » Sun Jun 14, 2009 11:14 pm
Those 3 three-pronged thingies are transistors. I suspect they are there to recover any gain lost from the loop.
The mod is actually a little easier than that, and you don't have to remove the transistors:
The 0 ohm resistors are those blue ones beside the jacks with the single black stripe.
[EDIT]I removed the footswitch mod because I don't have the complete documentation.
Guitars:Schecter C-1 Classic, Ibanez RG7321, Epiphone LP Supreme
Amps:70's Earth head
Cabs:Recto 4x12, 5150 4x12
Effects:Digitech GSP2101, Budwah
Past amps '95 Dual Recto, '96 Dual Recto, Stiletto Trident, 3 ch. Triple Rec
mcnamee
Post by mcnamee » Wed Sep 16, 2009 2:23 pm
Did anyone try the above instructions from mikey383? His handwriting a little tough to make out.
I have the same issue, I would prefer to try this myself rather that ship it off to voodoo amps for the modification. But I'm a little hesitant about haphazardly chopping up a $1400 amp :)
Any words of experience out there?
thx
Guitars: Gibson X-PLORER Studio with 2 EMG 81's, Hondo 2 Strat with EMG 81
Effects: ART SGX 2000 x 3, Dunlop Custom Audio Electronics Wah
Amps: TriAxis/2:90, Triple Rectifier, Marshall JCM800 50 Watt Combo
Cabs:Recto 4x12 Standard Straight and Slant
mikey383
Post by mikey383 » Wed Sep 16, 2009 11:38 pm
That's not my handwriting BTW, that's straight from Mesa. But here it is typed out for you:
1) Lift wiper wire of send and mix pots from rear jack board
2) Lift forward end of 0 ohm resistors next to send and return jacks
3) Add jumper from mix pot's empty pad to lifted end of return jack's 0 ohm resistor
4) Extend send pot's wiper wire to lifted end of send's 0 ohm resistor
mcnamee
Post by mcnamee » Thu Sep 17, 2009 10:36 am
Excellent, thanks for taking the time to type it out. It's cool that Meas will actually send you that kind of stuff, great PR.
dlabrecque
Post by dlabrecque » Tue Nov 17, 2009 2:21 pm
Just getting up to speed on this mod.
I understand that the FX loop switching at the footswitch is disabled by the mod, but that a mod to the footswitch fixes that. Do I understand right?
Also -- I thought I'd read that the mod also kills the solo and/or master output functionality. Is this true? If so, is there are fix for that/those losses?
Many thanks.
Dave Labrecque
Becket, Massachusetts
Dual Rectifier Roadster
4x12 Rectifier Slant Front
1x12 Compact Open Back
Boss MS-3 and various pedals
2002 Gibson SG
2006 Fender MIM Stratocaster
2006 Fender MIM Telecaster
2004 Taylor 510CE
Jerrick
Post by Jerrick » Tue Nov 17, 2009 8:41 pm
Would the Parallel to Series mod fix my issues?
Flip the loop on for red and orange channels, and it sounds horrible. Volume is very compressed and pinpointed, instead of being full and massive sounding. It was also really fizzy and scratchy.
So I bypass the loop and all is well.
I have a 2-channel dual rectifier, so are there any drawbacks for me here? All I hear about is the footswitch options on 3-channel rectifiers.
muramasa
Post by muramasa » Thu Nov 19, 2009 2:00 pm
Jerrick wrote:Would the Parallel to Series mod fix my issues?
I have a 2 ch triple rectifier and I used this http://forum.grailtone.com/viewtopic.php?f=4&t=28828 to convert mine to a serial loop. Problem was that even with this mod I still got bleed through. It wasn't any differnent than turning the mix and level knobs to 100%
Gibson les paul studio
Mark IV wide combo
Nova System
flimz
Post by flimz » Fri Nov 20, 2009 9:53 am
If this mod is directly from Mesa, will having an authorized Mesa tech do this mod void my warranty? Im guessing it will.
msi
Post by msi » Fri Nov 20, 2009 2:10 pm
Two of the three transistors are to enable and bypass the send and return jacks. Those are marked J125s, and J125r. The one marked J125m is part of the mute circuit and is there to lessen pops during channel switching. Without it you're liable to have the pop repeat during delay echos. I don't see any reason to remove j125m as it is not part of the loop circuit rather it's part of the channel switching circuit. Likewise the solo function should not be affected by this mod. Because J125s and J125m are bypassed and those control the loop on and off function, you can not disable the loop, and no number of modifications to the foot switch will change that.
Mark III Purple Stripe Combo S/N 18783
Dual Rectifier Rack Rev.F S/N R-001082
Triple Rectifier Rev.G S/N R-006420
Trem-O-Verb Combo S/N R-04706
Triaxis S/N T0265
2:90 S/N N-1573
ADA MP-1, Peavey 5150 Combo, DIY Slo 100, Line 6 Vetta Comb
dlabrecque
Post by dlabrecque » Fri Nov 20, 2009 2:11 pm
muramasa wrote: I have a 2 ch triple rectifier and I used this http://forum.grailtone.com/viewtopic.php?f=4&t=28828 to convert mine to a serial loop. Problem was that even with this mod I still got bleed through. It wasn't any differnent than turning the mix and level knobs to 100%
Are you saying that particular mod made no difference at all?
Dave Labrecque
2002 Gibson SG
2004 Taylor 510CE
