A very unique Revision G for you...
Silverwulf
Post by Silverwulf » Sat Mar 14, 2009 12:53 pm
Well, it seems that what we thought we knew about Rectos isn't 100% accurate. I give you Dual Recto R-003501. It's a Revision G wired up 2/24/94...BUT...it's built into a "Pre-500" chassis and has a factory serial loop. It looks, walks and talks like "Pre-500" by all appearance...but it's actually an early '94 Rev G. Here you go...
Boogie user of 20+ years, previous owner of 150+ Rectos, author of the previous "2 Channel Recto User Guide" and current "3 Channel Recto User Guide" (if I ever stop being lazy and finish it)...
Silverwulf
Re: A very unique Revision G for you...
Post by Silverwulf » Sat Mar 14, 2009 2:24 pm
As a quick side note, I haven't really gone over the amp too well yet other than the obvious, and I won't get a chance to plug it in until tomorrow. But, this raises a lot of questions and gives some topics for discussion...
All Rev G's were thought to have parallel loops. This Recto (R-003501) is roughly 700 units into the production of Rev G and features a serial loop. I've never seen another Rev G with a factory serial loop before (and I've seen a lot of Rectos). I've seen Rectos as early as the 2700's or 2800's feature parallel loops.
This is an actual "Pre-500" chassis, back from when Rev C and Rev D were in production. These chassis had not been used for pushing 1.5 years or so by the time this amp was made, wired up in Feb '94. So, why use a 1.5+ year old chassis and serial loop for seemingly one amp, right in the heart of when Rev G was starting to be produced?
These questions run through my mind. Most of all, I'm curious...how does it sound? I mean, if it shipped form Mesa in early '94 as a Rev G with a "Pre-500" chassis and serial loop...I wonder what other - if any - "mods" may have been done at the factory to this particular amp? And more importantly...why? I'm curious if this may have been some one-off model made for a signed artist?
I'll report back regarding tone after I plug in tomorrow.
Thrash Till Deth
Post by Thrash Till Deth » Sat Mar 14, 2009 2:26 pm
Maybe someone special ordered it with the serial loop and mesa did it because they still had chassis left over from the early rectos.
1995 Mesa 2 Channel Triple Rectifier (Chrome Chassis,Black Diamond Plate)
Randall MTS 4x12 Cabinets
2006 ESP Eclipse II
2007 ESP LTD RA-600
Silverwulf
Post by Silverwulf » Sat Mar 14, 2009 2:29 pm
Thrash Till Deth wrote:Maybe someone special ordered it with the serial loop and mesa did it because they still had chassis left over from the early rectos.
That's my best guess at the moment. I'll know more when I inspect it better and get a chance to plug in tomorrow.
clutch71
Post by clutch71 » Sat Mar 14, 2009 9:05 pm
I'm guessing it was sent back to Mesa for some reason...customer request? Note that it has the small logo as well. If memory serves by that range they were using the larger logo. I could be wrong though. Maybe the chasis and headshell were changed. Migs would know.
Well you've got a C to compare it to. This would be an interesting argument for revision vs. transformer argument.
Let us know.
On the mountain top, we are all snow leopards - Dr. Hunter S. Thompson
Silverwulf
Post by Silverwulf » Sat Mar 14, 2009 9:53 pm
clutch71 wrote:I'm guessing it was sent back to Mesa for some reason...customer request? Note that it has the small logo as well. If memory serves by that range they were using the larger logo. I could be wrong though. Maybe the chasis and headshell were changed. Migs would know.
Let us know.
The head shell is time appropriate. The small logos continued from the factory for roughly another year after this one was made.
The chassis is odd because it's a "Pre-500" chassis (as used on Rev C and Rev D), not just a "Pre-G" chassis like found on the Rev F and such. That means they had made another 2200+ Rectos with a serial loop that featured a slightly different chassis. This particular one hadn't been used in quite a while. If it was sent back, it would be more likely and make more sense that it would have featured the later serial loop chassis, not the "Pre-500."
If it did start life as a standard issue Rev G and was sent back to the factory, they would have also had to convert it from a parallel to a serial loop...then swap the serial number to the new chassis, etc. I can't see Mesa going to that trouble or even be willing to do that kind of swapping. I think it would have had to start life as you see it.
Right now I'm leaning towards it having to be a special order and it being shipped as it is. Possibly an artist special request, who knows? I'll be curious to know how it sounds when I plug it in. With a "Pre-500" chassis, I'm curious to know if it sounds like a Rev. G that it's supposed to be...or if it's tweaked to be basically a Rev. C or D. Guess I'll see tomorrow.
clutch71
Post by clutch71 » Sun Mar 15, 2009 7:03 am
I couldn't remember how far into the serial range the small logo extended.
Regardless, I think you've got an interesting amp there. I can't wait to here how you think it sounds.
Has anyone ever asked Mesa if they track where the serial numbers go to? I wonder if they at least track serial xxxx to xxxx went to dealer__________? If something was special ordered? Repairs or mods that came back to the factory? Warranty info? In all my time on this board I don't recall this questions being asked.
Another thought occured to me Silverwulf...is there another set of initials inside the amp anywhere. If Mesa brought it back to work on it, would they have signed it then as well?
Silverwulf
Post by Silverwulf » Sun Mar 15, 2009 9:08 am
clutch71 wrote:I couldn't remember how far into the serial range the small logo extended.
I've never asked specifically about serial numbers before, but I have asked in general and they noted that they didn't have records that were too specific. You can give them a serial number and they can give you approximate dates, like "it's probably a '93 or '94"...but they don't have records detailed enough to tell you "Oh, R-XXXX is a Rev. C made in 3/92" or anything like that.
At least that was the impression I got from them when I asked before, maybe someone else had a different experience. If an amp was sent back in to be repaired, I have seen them keep track of that, as well as mods. If this was some type special/artist order, they may have record. I'm going to give them a call on Monday and see if they have any record of it.
Regardless, it's definitely an interesting amp. I'll report back how it sounds.
Elpelotero
Road King
Post by Elpelotero » Sun Mar 15, 2009 12:28 pm
DUN DUN DUN!!!! and the plot thickens!
Also, what do you mean by "pre500 chassis" ? I may have skipped the explanation, or maybe I'm just not understanding completely.
'92 Dual Recto Rev. D, Volume mod
'84 Mark IIC+ Coliseum
'85 Mark IIC++ DRG, V1 mod
Mesa Standard 4x12
1980's EV Thiele
Sold:
'92 Dual Recto Rev. C
'92 Dual Recto Rev. E
'05 Dual Recto 3ch
'84 Mark IIC+ DR
http://www.TheBoogieArchives.com
Silverwulf
Post by Silverwulf » Sun Mar 15, 2009 1:16 pm
Elpelotero wrote:DUN DUN DUN!!!! and the plot thickens!
Oh, sorry about that. If you notice, the "Pre-500" chassis have one difference back they were first produced. If you look under the "Orange Channel Gain" selector switch, under the "Clean Rhythm" side...the "Pre-500" have the additional screening that says "Channel Volume 7-10." This was dropped on the later chassis after they tweaked the revisions and equalized the volumes. The chassis on R-003501 features that notation (as seen on the last pic).
Going to plug in this evening. Interested to see how it plays.
jtxdriggers
Post by jtxdriggers » Sun Mar 15, 2009 2:50 pm
I assume this is your new blackface "revision F" that you were considering selling me ;)
What about the impedance on the outputs? Don't revision G's have 16, 8, 4, 4? And revisions C-F have 8-16, 8-16, 4, 4? I know there are some on record with the older configuration, and I'm sure this could be an addition to the acception.
Mesa Boogie Dual Rectifier (Rev F, R-002080)
Blackface, Chrome Chassis
Marshall 1960a 4x12" Celestion G12T-75's
ESP Deluxe H-1001 w/ EMG 81 & 85
Silverwulf
Post by Silverwulf » Sun Mar 15, 2009 4:08 pm
jtxdriggers wrote:I assume this is your new blackface "revision F" that you were considering selling me ;)
No, this is actually another Recto... :lol: I gave up trying to keep my signature up to date. I'll update it again when I settle on a few amps. I've got 4 Rectos downstairs at the moment.
The outputs lack consistency. The older Rectos do feature a 16-8/16-8/4/4 configuration and later models have a 16/8/4/4. However, the Rev F Triple (from late '92) has the later 16/8/4/4 configuration and the older 16-8/16-8/4/4 configuration was still scattered on Rectos into as late as early '95 that I've seen.
Silverwulf
Post by Silverwulf » Sun Mar 15, 2009 4:22 pm
Initial impressions...took the tubes from the Rev C and put them into R-003501. Set the dials on Channel 2, "Modern" and gave it a whirl. My first impression...I was quite surprised. Honestly, it's very close to Rev C. In fact, it's scary close. After a while I think my ears started getting fatigued, so please bear in mind this is my initial impression. I'm going to revisit after a few days (prob Tuesday) and do comparisons again. But as of right now, it's pretty damn amazing how close Channel 2 was to Rev C.
So, I flipped over to Channel 1. Considering it's built into a "Pre-500" chassis and Channel 2 sounded scary close to Rev C, I started to wonder if it would have the same (lack of a) clean channel. Set the dials, started rolling up the volume...and instant clean volume. Played around with chords, single note stuff, etc. It was pretty much instantly recognizable in my mind with little doubt that the cleans are hands down Rev G.
So, this has turned out to be quite a surprise. My initial impression after tube swapping and playing for about 1.5 hours is that Channel 1 is without a doubt a stock Rev G sounding channel, especially on the cleans. However, Channel 2 is very scary close to Rev C, so close in fact I doubt my band mates would know the difference if I swapped head units during our break in practice on Tues.
I need to do a lot more comparison, and I want to get some more ears involved...but right now, there's a lot of things that are definitely out of the ordinary for a stock Rev G.
Elpelotero
Road King
Post by Elpelotero » Sun Mar 15, 2009 4:51 pm
that is ridiculous....wow. Must be an artist model or something. Call Mesa and talk to Mike B or someone who knows their stuff.
Mesa Standard 4x12
1980's EV Thiele
Sold:
'05 Dual Recto 3ch
'84 Mark IIC+ DR
Silverwulf
Post by Silverwulf » Sun Mar 15, 2009 6:17 pm
Elpelotero wrote:that is ridiculous....wow. Must be an artist model or something. Call Mesa and talk to Mike B or someone who knows their stuff.
Yeah, I'm going to give them a call tomorrow and see what they can tell me, if they even have any record of it. It was made a good 15 years ago, so I don't know if they'd have any info of anything that was done at the factory at this point. It's definitely a diamond in the rough.
I would have been perfectly happy with a stock Rev G with a factory serial loop. But this definitely has something more done to it. I haven't tried "Vintage High Gain" on Channel 1 yet, so that should be interesting. I'm gonna give my ears a break and get some opinions other than my own on Tues. Not that I don't trust my ears, but it's always good to get some other opinions.
