Modding my Triple Rectifier Effects Loop Tomorrow
jakeleigh
London, UK
Hi,
I've decided to mod my effects loop from Parallel to series and I'm taking it in to the tech tomorrow. I have no problem with losing the solo boost/master volume as I always run it on bypass anyway but it is possible to keep the foot switchable loop on/off function? I'm not able to get in touch with the tech until tomorrow afternoon and I'm not really up for getting it done if I cant bypass the loop still with the foot switch. I have done a bit of research on these forums already but found conflicting opinions.
Thanks for your help!
When you go from parallel to series - if you don't already know - the loop and solo buttons will function exactly the same.
