clutch71 said:
Without a lot of tube experience I can tell you experimentation with different tubes will create subtle differences. I ordered a set from Doug tubes and went with his recommendation. The amp was a Marshall but drop him an e-mail and see what he suggests for the TOV.
I went with a Tungsol in V-1, Penta Labs in V-2, JJecc83 in V-3 and an balanced unbranded in V-4. Doug originally suggested an EH in V4. It was bad so Doug sent me another. I liked the unbranded tube in V-4 so I left it. I'm a firm believer in a balanced PI.
Later I tried other combination including other Mesa, JJ, and mixing up the order he suggested. Ultimately what you see above is what I still run. I orded a back up set I like it so much. Just my .02.
clutch, thanks so much for the feedback. doug actually suggested the tungsol and the sovtek LPS for my amp. i only asked for V1 and V6 positions. what tone differences do you notice with replacing V2-V5? i've always stuck to the stock mesa tubes but i've gotten to a point where I would try different things and see what they can produce.
also, do you have any sound clips of the config you use currently? i'd like to know what to expect if i try out your suggestion.
