Roadster Footswitch Cable
spanny
Chicago
I was wondering where you can order or get Roadster footswitch cables? I am looking for one that is around 25' and couldn't find anywhere on their website.
what should I search? i couldnt get any results for the key words I could think of.
ValveHeavyTone said:
Musicians Friend
Do you have a link? I can't find any 8-pin MIDI cables there.
I did find this on Ebay, it's an extention cable you could use to lenghten your original cable:
http://cgi.ebay.com/1-20-8-pin-Midi-cable-male-to-female_W0QQitemZ310079085574QQcmdZViewItem
Dom
its a 7 pin that you need bro!
http://accessories.musiciansfriend.com/product/Hosa-7Pin-Phantom-MIDI-Cable?sku=333039
Thanks.
Hmm....... Mine is 8-pin. Perhaps the center pin is not used?
Looks like I might have to satisfy that curiosity and crack open my footswitch :? :!:
Dom
Yea, mine is 8 pin too. Though if it only eliminates the tuner mute or solo button, I wouldnt really care much.
I opened the Roadster's footswitch and the center pin of the 8-pin DIN connector is not used. Mesa most likely uses the same cable/connectors between the Roadster and RK.
A 7-pin MIDI cable should work fine with the Roadster.
Dom
Dom
that is good news for me
For whatever reason the cables are in the "Hardware" section and NOT with the footswitches . Perhaps that is
the correct area , but I am with you , hard to find them .
http://mesa.stores.yahoo.net/cbl-8pindin15.html
30 bucks you can get 20/25/30footers , 7 and 8 pin .
/cheers
