Musicians Friendspanny said:I was wondering where you can order or get Roadster footswitch cables? I am looking for one that is around 25' and couldn't find anywhere on their website.
ValveHeavyTone said:Musicians Friend
its a 7 pin that you need bro!domct203 said:ValveHeavyTone said:Musicians Friend
Do you have a link? I can't find any 8-pin MIDI cables there.
I did find this on Ebay, it's an extention cable you could use to lenghten your original cable:
http://cgi.ebay.com/1-20-8-pin-Midi-cable-male-to-female_W0QQitemZ310079085574QQcmdZViewItem
Dom
ValveHeavyTone said:its a 7 pin that you need bro!domct203 said:ValveHeavyTone said:Musicians Friend
Dom
http://accessories.musiciansfriend.com/product/Hosa-7Pin-Phantom-MIDI-Cable?sku=333039
that is good news for medomct203 said:I opened the Roadster's footswitch and the center pin of the 8-pin DIN connector is not used. Mesa most likely uses the same cable/connectors between the Roadster and RK.
A 7-pin MIDI cable should work fine with the Roadster.
Dom
