MrBoggles
ok during the 2nd set of a show we lost power,
after it came on again i turned on the amp quickly and probly didnt give it enough time to warm up.
here's the problem the amp started squeeling so i know something was going on with the tubes so i turned it off and waited and then turned it on again after the tubes had warmed up several times. There was no visual indication that the power tubes were playing up and the noise eventually stopped. :?
however after that i lost substantual volume to ch 2+3. ch 1 was fine.
Which led me to thinking it was the power tubes, but after concidering that ch 1 was fine i'm thinking it could be v2 or v3 that was playing up. again concidering that v2 contains boost stage for all 3 channels and that ch1 was fine i'm thinking V3 is the culprit..
after leaving it on standby during the set break upon returning everything was back to normal :?
the weird thing is i've only just put new v1 v2 v3 in no less that a few months back and it has performed flawlessly up until this point. so dud tube??
what do you think??? any thoughts are aprciated..
