It is currently Wed Jan 23, 2019 4:53 am
PostPosted: Sat Nov 09, 2013 4:57 pm
Living in an urban condo -- not really able to bust out my boogie for recording. Been playing around with Amplitude and GuitarRig5 and was wondering what if any amp sims you'd recommend that would be similar to my boogie?
Fully loaded IIC+ Hardwood, simul....
PostPosted: Mon Nov 11, 2013 8:24 pm
Look up the amp sum called "Lecto" heard amazing clips of that one.
2008 Triple Rec
Dean '79 V (Dean Tyrant/dimarzio mystery neck)
LTD Ninja 600 (SD Black Winter/59)
Epiphone Les Paul Standard (EMG 81/85
Ibanez GAX70 (EMG 81)
Hamer Standard (Golden Age Hot PAF w/ ceramic magnets)
BC Rich Warlock (L500-XL's)
PostPosted: Mon Dec 09, 2013 1:24 pm
Depends what specific amp it is. If you have a Rectifier, then yes, Lecto. If it's a Mark series (I see a IIC+ in your sig), the only one I know is the Mark III sim in Amplitube, which gets a lot of mixed reviews.
Joined the Boogie family on May 18th, 2013: Mark IVA combo <3
Fender Stratocaster HSS + pedals
Like Joe Satriani and Dream Theater? Check out my new project!
The Nocturnal Dawn: Facebook, Soundcloud, Reverbnation, YouTube
PostPosted: Fri Dec 13, 2013 10:59 am
you should just get a kemper profiler
'81 Mark 2B head ~ 60watt-GEQ
BatsBrew
http://www.cdbaby.com/cd/batsbrew
https://soundcloud.com/bats-brew
PostPosted: Fri Dec 13, 2013 2:13 pm
Lecto and Legion cover all the Mesa line when used together.
Dual Rectifier
Recto 4 x 12 Straight v30s
Ibanez RG560
BC Rich Beast (Fully Understand it's namesake now)
"Efficiunt Daemones, ut quae non sunt, sic tamen quasi sint, conspicienda hominibus exhibeant." - Lactantius
PostPosted: Thu Jan 09, 2014 12:07 pm
i use my boogie late at night sometimes..
so i use a weber mass lite attenuator...
and a Palmer PDI-09 to capture the 'full output sound' of the amp head going thru a 4x12 cab, at line level..
while actually using a 1x12 at low volume
this records really really well.
BatsBrew
PostPosted: Sat Jan 11, 2014 3:58 pm
Axe FX - hands down. The mesa models in that unit are amazing.
PostPosted: Sat Jan 25, 2014 9:59 pm
I use a Tech 21 Tri-AC pedal and like it a lot.
Good clean and distortion tones. Not fond of the Marshall but love the Fender (sort of) cleans and the Mesa lead tones I get running direct.
100% analog signal path, it feels right when you play.
Great pedal to have in your gig back for backup duty also. Any amp that works or straight through the PA will get you through the gig.
There is never enough time to be in a hurry.
Currently in possesion:
Dual Caliber DC-5 1-12
Gone but not forgotten:
Subway Rocket
Blue Angel 1-12
Mesa Maverick 1-12
Subway Blues
.22 Caliber
Mark IIIC Simul-class head w/reverb and eq
PostPosted: Mon Feb 24, 2014 2:54 am
^ If you can afford to shell out some, this. The Axe-FX also has some good boogie sounds.
New album available at:
Spotify: https://goo.gl/PdPVYh
Bandcamp: https://deathbenotproud.bandcamp.com
iTunes: https://goo.gl/PPSziC
Amazon: http://a.co/1aF6Pe3
GooglePlay: https://goo.gl/FdQGtA
PostPosted: Sat Jan 24, 2015 3:36 am
I will rebut my post earlier. I was turned on to this guy's stuff a couple weeks ago.
https://pvdhp7.wordpress.com/page/2/
His Rectifier head sounds better than LePou. He also has a Mark iii sim that is close, but it only has gain and volume controls. This may be a bummer for most, but I found it to work extremely well in recording as whatever tone settings he programmed cut through everything and when eq'ed at the board can get really mean sounding.
The amp sim is only a portion of the equation though. I think that cabinet impulses are as important or maybe even more so than the amp sim.
Dual Rectifier
Ibanez RG560
PostPosted: Sun Jan 25, 2015 11:53 am
Hello!
If you are looking for a amp sim, then Bias is a very good amp sim program.
But if you really want a good thing that you can do recordings with, then I can recommend Kemper Profiler Amp, it's not so expensive like the Axe Fx and I have tested both and compared them and I must say that the Kemper won.
2B
Mesa Boogie Mark V 25, Kemper Amp.
Sterling by Music Man JP100D, LTD MH-350R (Crunch Lab & LiquFire), Ibanez EGEN-8 (DiMarzio Evolutions), Washburn N2 (modded to a N4), Washburn N1 (Gotoh tremolo, DiMarzio JBJ bridge, DiMarzio '59 neck), Dean C350F.
