F-30 recording out/silent recording
roburado
How well does the F-30 silent recording function work? Honestly, I didn't even realize I had one until I checked the manual to see how to use the effects loop.
I assume there's no speaker emulation.
No speaker emulation at all, raw head, which isn't really good. Plug it into a Podxt/J-station/V-amp and turn off the amp emulation and just use the cab simulators and you can plug it into you computer. That's at least how I do it with my Mark IV and J-station :)
Thanks. I just might try that PODxt idea. First, I have to figure out how to do it. :)
ive used the silent recording feature on my friends f-50. I have never had good luck with speaker emulation. You could always record it straight in and re-amp it later.
That silent recording feature on the F series is worthless imo.
I've had pretty good results using a HotPlate as a load box and using the line out on the Hotplate and then using cabinet emulation from my Toneport.
