Mesa Mark IV A fx loop problem
Forum specific news and announcements
Discordantsystem86
Post by Discordantsystem86 » Thu Oct 10, 2019 7:35 am
Hi guys, I'm having some problems with the fx loop of my Mark IV A, especially on the clean channel. If I have no fx connected in the loop the amp sounds awesome. If I connect for example a delay, even with short cables, the clean channel distorts, and I have a sort of volume drop. I've tried to change preamp tubes but nothing. I've had this problem when I bought the amp, after retubing the problem was solved, today I'm having the same problem. I have 4 Ruby 6L6s in the power section and in the preamp section a Tung Sol 12AX7 in v1, Ruby 12AX7AC5 HG V2, Electro Harmonix 12AX7 V3, Tung Sol 12AT7 V4 and a Sovtek 12AX7 LPS in V5. Please tell me what you think, if you have had the same problem. Thanks a lot
Discordantsystem86
Re: Mesa Mark IV A fx loop problem
Post by Discordantsystem86 » Thu Oct 10, 2019 7:53 am
If I connect a patch cable between the send and the return the amp works great again, so a friend of mine told me that could be a flip flop transistor of the delay that is gone and distort the signal.
stephen sawall
Post by stephen sawall » Fri Oct 11, 2019 8:09 pm
You might be sending too hot of a signal to the delay.... Read the manual to properly set levels.
R1 Master / R2 Master / Lead Master these control the send level in the effects loop. If you set them too high for your pedal it is going to distort.
Discordantsystem86
Post by Discordantsystem86 » Sat Oct 12, 2019 8:52 am
Hi Stephen, we have tried with a Boss DD7 and with the same settings we had no problem, so it's a pedal problem for sure. Thanks a lot
stephen sawall
Post by stephen sawall » Mon Oct 14, 2019 7:36 am
Every pedal has different input levels....you need to adjust your amp different for every pedal.
